Next mods
Next mods
Airaid cold air intake
BBK 90 mm throttle body
I will install in the spring after I pull the stang out of storage. But what mods would I need to further add to get in the area of 450whp. My mods so far are
Steeda cat delete pipes
Stainless side burners
Roush axle back resonator deletes
Bama tuned and the car hauls *** but I want more lol any help thanks
Former Vendor
450RWHP+ is absolutely achievable on the 2011+ 5 O's. I would go with a set of long tubes to start, that will pick up about 15-20 RWHP! I would then go with either a Boss Manifold and 90 MM TB or a Cobra Jet Manifold, 65MM Oval TB and a Custom CAI. Either of these set ups will definitely help you get closer to you goal!
Last but not least, I would go with a set of Cams. The 2011+ GT's pick up around 40+RWHP from a set of Comp Cams! I've seen 5.0's dyno anywhere from 465-520 RWHP all motor. If you just do the cams, you can expect to be between 465-480 RWHP. While you're doing the cams, if you port your heads a bit you can expect to see a little over 500 RWHP!
I'm in the process of doing, Heads, Cams, Cobra Jet, Clutch and a 100 shot in my 2011 GT! This is the best way to go low to mid 10's in the quarter mile.
I hope this helps. Remember, this is just my opinion! Let me know if you have any questions or need some assistance in the near future.
-Dan
I think a boss 302 manifold with a 90 mm tb and the airaid cal will be as far as I go that should bring it **** close. Long tubes while good the install no thanks lol
Here what I'm going to do with my tax return lol
Boss 302 manifold
Ford racing boss 302 engine cover kit
Boss 302 manifold install kit
And boss 302 strut tower brace
The tb can wait
Boss 302 manifold
The tb can wait
Former Vendor
Please let me know if you have any questions or need some assistance in the future!
-Dan
And long tubes are great but because the plant puts the engine up through the chassis u would have to lift the motor to put then in a lot of work for 15whp to 25whp just saying
