Newbs Guide to Automotive Fundamentals
I stumbled across this guy's channel on YouTube, and was pretty impressed with his videos especially given his age. I figure some of you guys could benefit from watching some of these.
His channel is EngineeringExplained
Twin-Screw Superchargers:
Roots Superchargers:
Centrifugal Superchargers:
Turbo Lag:
Auto vs Manual:
Gears:
First Gear Torque:
Torque Coverters:
Clutches:
Multi-Plate Clutches:
Dual Clutch Transmissions:
Cylinder Deactivation:
Ignition System:
Fuel Injection:
Carburetors:
Starting Your Car:
Engine Cooling:
Horsepower vs Torque:
Compression Ratio:
ABS System:
Disc Brakes:
Drum Brakes:
Camber:
Steering Axis Inclination:
Open vs Locked Differentials:
Engine Layouts:
DOHC vs SOHC vs OHV:
Octane Rating:
Traction Circle:
Traction Control:
Stability Control:
Front Wheel Drive:
Rear Wheel Drive:
Hemi Engines:
Nissan GT-R Nut Hug:
Turbo Lag:
Auto vs Manual:
Gears:
First Gear Torque:
Torque Coverters:
Clutches:
Ignition System:
Fuel Injection:
Carburetors:
Starting Your Car:
Engine Cooling:
Compression Ratio:
ABS System:
Disc Brakes:
Drum Brakes:
Camber:
Engine Layouts:
Octane Rating:
Traction Circle:
Traction Control:
Stability Control:
Front Wheel Drive:
Rear Wheel Drive:
Hemi Engines:
roushcollection
Jul 28, 2015 02:08 PM
Detroit Steel
Jul 28, 2015 12:53 PM
