New front fascia?
New front fascia?
I keep reading about a supposed "new front facia" for the 2011 GT. Looking at pictures of the '10 and '11 I'm not seeing any difference. I know the chin spoiler is a little deeper and some of the articles mention that separately. There's also the new "diaper" on the other end. Could they be confusing the front or the car for the rear?
Here's a quote from a new Motor Trend news article about the 2011 GT's fuel economy:
Engineers also installed a restyled front clip, taller air ****, rear tire spats, new underbody cladding, and rear decklid seal to provide a more aerodynamic form. A new electronic power steering assembly replaces the engine-operated hydraulic power steering pump and cuts its drag from the GT's efficiency equation.
I'm hoping that you will be able to just remove the bottom part of the bumper cover and put in the California Special air dam, rather than replace the entire bumper cover. We ought to know in another month, I guess.
To Convert the Base Gt Front End to Gt/CS You would need the Following.
Grille Shell
Grille
Grille Emblem
Lower Fascia
R&L Fog Lamp Inserts
R&L Fog Lamps
R&L Fog Lamp Piggs
Lower Belly Pan
Some Items are Priced at Ford Some are not. Availability will be mid next month.
KC
Grille Shell
Grille
Grille Emblem
Lower Fascia
R&L Fog Lamps
R&L Fog Lamp Piggs
Lower Belly Pan
KC
So if the 2010 and the 2011 front fascia are almost the same would this Roush for a 2010 fit?
http://store.roushperformance.com/detail.aspx?ID=1200
