Need help with spring install
Old May 23, 2012 | 05:30 PM
Tron84's Avatar
Am I missing something here? How am I suppose to use a wrench to loosen the 22mm nut on the top of the strut? If I use a socket I can't put a wrench on the strut to keep it from spinning.
Every installation instructions show a different upper strut mount where the nut is out in the open on top, not sunken down there.
This is on a 2012 GT. Any help would be greatly appriciated. I'm starting to get frustrated
Size:  134.8 KBName:  P1010720.jpg
Old May 23, 2012 | 05:59 PM
Tron84's Avatar
Well got it apart to just to find out that the gt500 strut mounts don't work with the oem struts
Old May 23, 2012 | 06:04 PM
ScottH's Avatar
I saw that you got the strut nut loose, but next time, loosen that nut before you jack the car up. Makes it a ton easier.
And yeah, GT500 mounts and oem GT struts = no joy.
Old May 23, 2012 | 06:14 PM
Tron84's Avatar
Weird, just before I came over to the computer and read your reply I thought about that but figured the strut would still spin. But you are correct sir, that IS the way to do it.
That will definatly make the other side much easier!!
THANKS!
dohc97
16
Sep 24, 2015 05:40 PM
SMBJoshy
Aug 24, 2015 10:55 AM
RocStar69
Aug 21, 2015 07:33 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
