Need bigger impact gun!!
Old May 1, 2015 | 12:54 PM
imeyers302's Avatar
Went to install my Koni sports and could not get one of the two lower strut bolts out. My impact gun is supposed to go to 250ft lbs but no luck. Tried breaker bar too. Bottom one came out no prob but top one ain't going anywhere yet. Need to get a different socket for my larger breaker bar and give that a try. Anyone else get stuck on this?
Old May 1, 2015 | 02:12 PM
Horspla's Avatar
Nope...big arms, a big breaker bar and a determined person! My impact gun wouldn't do it either. I think those pinch bolts are torqued to around 300ft/lbs.
John
Old May 1, 2015 | 03:02 PM
imeyers302's Avatar
John
A contractor friend of mine is lending me a more powerful air impact gun. My cordless just does not have enough juice. Dont want to use a huge breaker bar because if it slips its going to hit the fender.
Old May 1, 2015 | 03:06 PM
Joeywhat's Avatar
Just be aware that impacts can ruin bolts pretty quick. I always use a breaker bar for stuck bolts, to avoid rounding the head or snapping the bolt.
Old May 1, 2015 | 03:27 PM
imeyers302's Avatar
I know but after checking my impact gun is only 200ft lbs. Those bolts are normally torqued to 166ft lbs. My dealer installed my springs before I bought the car so no telling if they just used an impact and just made it real tight. 200ft lbs is not enough torque.
Old May 1, 2015 | 03:31 PM
Blown CS's Avatar
When changing struts I use my cheapo harbor freight 700 ft lb. and I never have any trouble.
Old May 1, 2015 | 04:35 PM
Horspla's Avatar
166ft/lbs? God it sure seemed like more than that to me. I guess I am getting old!
I do agree though about ultra high torque impact wrenches. I've watched a lot of bolts go rolling to the floor followed by an entire dictionaries worth of explatives.
Good luck
John
Old May 1, 2015 | 05:24 PM
Blue Notch's Avatar
I had a lot of trouble with mine too, but raising/lowering the control arm and a breaker bar along with some kroil got it off for me.
Old May 1, 2015 | 05:46 PM
imeyers302's Avatar
Trust me its the cordless impact driver I have. It could not take out the panhard bar bolt either and that's not torqued that much. Can't use an impact driver. Needs to be an impact wrench. The Milwaukee Fuel I have is awesome for anything that does not require huge torque. But over 150ft lbs and it has trouble. Will give it a little support while removing it.
Old May 1, 2015 | 05:48 PM
Joeywhat's Avatar
Cordless impacts aren't very powerful to begin with. I only use mine for stuff 80 ft lbs or less.
If you do use a stronger impact, make sure to have a very good 6 point socket that fits the bolt head snuggly... Otherwise have fun with the rounded head. Never use a 12 point with an impact.
Old May 1, 2015 | 05:54 PM
Blue Notch's Avatar
My air gun couldn't get it off either. Had to get creative with a breaker bar and extensions. Probably not ideal, but it got the job done.
Old May 1, 2015 | 06:12 PM
tom281's Avatar
In my experience cordless impacts are almost useless and air impacts are only as good as the volume of air you can supply not psi.
Old May 1, 2015 | 06:18 PM
imeyers302's Avatar
I have a 1.8hp 20gal tank air compressor. Will that do the trick? And I agree with you on the cordless. They really are not good for high power.
Old May 1, 2015 | 06:23 PM
Joeywhat's Avatar
Cordless is great for lower torqued bolts. I use mine all the time. Just have to know it's limitations and not expect it to perform like a 3/4" air impact.
Old May 3, 2015 | 04:05 PM
rmurer's Avatar
gym membership
Old May 3, 2015 | 08:30 PM
5.M0NSTER's Avatar
Originally Posted by rmurer
gym membership
There are very few things in this word which can't be resolved with the right amount of excessive force. Like it? I made this contradiction up myself
Old May 4, 2015 | 05:07 AM
imeyers302's Avatar
gym membership
Dont need one. My gym is in my basement.
Old May 4, 2015 | 10:08 AM
scott9050's Avatar
Cordless one I use:
http://www.milwaukeetool.com/power-t...rdless/2663-22
Only one nut I have not been able to break off with it, 32 MM strut rod nut from a northern Mark VIII.
Old May 4, 2015 | 10:27 AM
LEXiiON's Avatar
Originally Posted by scott9050
Cordless one I use:
I have the same one. Works great...
LEXiiON
Old May 4, 2015 | 04:01 PM
Cobra99's Avatar
why not use a snipe or cheater pipe
