My Apologies to Justin and VMP
Old Jul 9, 2014 | 05:14 PM
rmurer's Avatar
So most of you that frequent this sub-forum the issues I have been having and my attempts at putting the blame on VMP and Justin's tunes.
I had gotten another email from Justin today where he thought it was accel pedal still, something was wrong with it. And I started to believe it more because when you look at the logs with the accel pedal to the floor it techinically is only 60% depressed. So when I got home from work i decided to take a look. There appeared to be a hard foam block that I assume is to prevent the accel pedal to much travel where it would break it. So I cut the darn thing to let the pedal actually travel all the way. Go in the car and did a log.
HOLY CRAP HOW LONG HAS IT BEEN LIKE THIS???????????
Completely different car.. When its to the floor the pedal travels to 99.5% which is close enough for me. The log shows that the car is suppose to do exactly what its suppose to now that everything is working properly. A/F goes to where its suppose to at WOT.
Since its an auto I did a turn around put it into 2nd, and nailed the gas, did a burn out starting in second...HOLY MOSES.
So I would like to apologize for anything wrong i said about Justin and VMP. Wasn't my fault, wasn't his fault. Seemed to be a pedal issue and it not traveling far enough.
Here is a picture of what im talking about.
Old Jul 9, 2014 | 05:30 PM
rmurer's Avatar
side note i didn't remove all of it as you can see just enough to where the pedal when pressed all the way down will travel to 100% without issue.
Yes i know this probably wasn't the SMARTEST way to fix it but seriously with all the frustration i was going to, I said F it.
The logs show everthing is now how it should be.
Old Jul 9, 2014 | 05:39 PM
holy moly that's weird. I would think some sensor, an adjustment or some other problem over what you had to do. Not right.
Old Jul 9, 2014 | 05:43 PM
Had you ever recalibrated the throttle after the battery was unhooked so the ECU learned 'the range'? Some say this should be done after a tune is loaded too.
Old Jul 9, 2014 | 06:15 PM
14Glassback's Avatar
How do you recalibrate the throttle?
Old Jul 9, 2014 | 06:52 PM
I found this a few years back on some old posts concerning throttle lag and recalibrating the throttle after battery disconnect for the 4.6L3V.
Recalibrate fly by wire throttle:
1. Turn on car without starting the engine
2. Wait till most the dash lights go out (seems like two remain on)
3. Step on the gas pedal in one smooth and steady motion
4. Once gas pedal hits the bottom, let go
5. Turn off car and wait 4-5 seconds
6. Turn engine on
7. Drive
Repeat 1-6 if it doesn't work the first time.
They also say you need to do this everytime you change tunes.
Idle re-learn:
The idle learning process is simple. From a cold start, load your tune - or in this case since you're not running a tune just unplug the battery overnight.
Then from a cold start, start the car and idle for 8 minutes without touching the throttle at all.
Now put the A/C on for 2 minutes, still at idle without touching the throttle at all and without shutting of the car.
Now after 10 minutes of idling (8 without AC and 2 with AC), you can drive the car for approximately 10 miles... make sure it's not just highway, but stop signs, traffic slights, etc.
You will have completed the idle learning process.
I do both any time I have disconnected the battery. Definitely notice a difference in responsiveness.
Old Jul 9, 2014 | 06:58 PM
rmurer's Avatar
I tried the relearn a couple times and it made no difference. Cause i was looking into this while at work this morning and had the same thought's and came across the same "fix"
Old Jul 9, 2014 | 07:22 PM
Blown CS's Avatar
Glad you figured it out, Im off to the garage to have a look. Bet the found power brings a smile to your face.
puma1552's Avatar
Pretty sure you shouldn't have had to hack a hole in the floor to get the performance you were supposed to?
Old Jul 9, 2014 | 07:24 PM
rmurer's Avatar
its carpet lets not get to crazy calling it flooring.
the pedal could be bent slightly for all i know but the pedal and or pedal travel was the issue.
Old Jul 9, 2014 | 08:15 PM
puma1552's Avatar
Why'd you delete the picture?
Old Jul 9, 2014 | 08:35 PM
Blown CS's Avatar
I still see the picture!
Old Jul 9, 2014 | 08:38 PM
rmurer's Avatar
I did? I shall fix that, i made an edit real quick and i think i accidently deleted it.
Old Jul 9, 2014 | 08:39 PM
puma1552's Avatar
Doesn't show up anymore in my browser after the OP was edited, tried another browser and I get an ad in its place. *shrug*
Old Jul 9, 2014 | 09:35 PM
Joeywhat's Avatar
Pedal must be bent. I can't see any other explanation. I would look into that, if it is bent it could be seriously weakened and could break.
Old Jul 9, 2014 | 10:05 PM
I haven't looked on my car yet, but every single Ford I've owned or driven has had slop in the gas pedal, resulting in at least another inch of travel that is not being used. In the SN95 world, people would put plastic spacers on the cable to push the pedal up - this would make WOT happen sooner and make heel/toe a lot easier. Are our cars like this? I know there's no cable, but could there be the same slop?
Old Jul 9, 2014 | 10:08 PM
Joeywhat's Avatar
I looked at my V6 pedal earlier today and didn't notice any.
Old Jul 9, 2014 | 10:17 PM
Hmm well there goes that theory haha. I didn't notice any while driving my GT either.
Old Jul 9, 2014 | 11:02 PM
LEXiiON's Avatar
I don't have that block in mine. Just carpet. I am not sure if that is supposed to be there.
LEXiiON
Old Jul 9, 2014 | 11:06 PM
LEXiiON
Maybe his was a rental car.
