Mutton Chops
Old Dec 11, 2008 | 04:51 PM
zzcoop's Avatar
Every time I see that guy, this is the first thing that comes to mind:
Old Dec 11, 2008 | 07:03 PM
TampaBear67's Avatar
Originally Posted by Stormbringer
AHHHHH! This picture helps. I can see the resemblance here. I kept thinking 70's Elvis but this is much closer.
Uh, them were Pork Chop Sideburns.
Thank Ya'.... Thank Ya' Very Much, Uhh Huhhh.
Can ya' pass me sum ah them there mashed tatters?
I should know, I've worn them with my Goatee for the last 15-20 years off and on. Well not quite as big as E's.
Old Dec 11, 2008 | 08:21 PM
Black GT500's Avatar
PhotoCHOPPED Mutton Chops
Well Here is a PhotoCHOPPED Mutton Chops on a 2010 just for you...
Old Dec 11, 2008 | 10:46 PM
fdjizm's Avatar
.........And thats when i knew i had learned too much about sideburns.
Old Dec 12, 2008 | 11:17 AM
Here's a Couple of pic's I did to help show the Aerodynamic Effects of the "Mutton Chops" and their Little Brother's "Sideburn's" on the V6.
The Blue Arrows represent the airflow coming at the Front Bumper. As it passes the edge of the Bumper. On the GT, the vertical section at the front of the
"Mutton Chops" separates the air flow and directs it two ways. Into the Lower grill area for cooling and around the side which by having the hollowed out area created by the "Mutton Chops" the air is forced to flow out and around the side of the car and around the tires.
The Yellow Arrows represent the air that makes it under the Front Bumper. It is then caught by the Air Dam underneath the Front Bumper and directed around to the side of the car, also past the tires.
The Green Arrows actually represent the higher pressure points that would create a pocket and actually catch the air and cause drag. As the sections on each side of the Lower Grill on the GT are Blocked off and do not allow air to flow through. However, this may prove beneficial to forcing greater amounts of air through the actual opening Benefiting cooling. On the V6 the same also applies to the outer corners of the Lower Grill, and the Pockets created by the Fog Lamp openings.
Attached Thumbnails Mutton Chops-aero-lesson-2.jpg   Mutton Chops-aero-lesson-1-.jpg
Old Dec 12, 2008 | 11:31 AM
Mustang Buster's Avatar
Great illustrations Shawn. IMHO, the V6 facia looks so much more stylistically integrated and better thought out than the GT design. Whereas the GT facia almost looks like the Mutton Chops were aero add ons that they tried to integrate into the styling after the fact.
Old Dec 12, 2008 | 12:17 PM
Greywolf's Avatar
I agree with you Mustang Buster
Old Dec 12, 2008 | 12:59 PM
dhg2496's Avatar
Can someone use photoshop or paint to extend the bumper down and fill in that gap in the mutton chops? I think it would make the chops a lot less noticable and give it more of the V6's style.
Old Dec 12, 2008 | 02:55 PM
zzcoop's Avatar
Here's my take on the mutton chop thing. Basically, I just filled them in and made them cover more of the bumper, rather than just hanging out there like the little winglets they are now. Also, since I hadn't seen it done yet, I went ahead and blacked out the body-colored strip below the lower grille.
Old Dec 12, 2008 | 03:10 PM
RedCandy5.0's Avatar
Any other pics of the V6 other than the silver one. I can not belive how much better everything looks on it.
Old Dec 12, 2008 | 04:48 PM
Looks Good that way Coop. I think we'll see A Lot of GT's moded that way. It's a Cheap and Easy fix. You could probably do it your self with some Heavy Duty, Semi Gloss Black Vinyl Tape.
Old Dec 12, 2008 | 09:50 PM
jay_wx's Avatar
Does that remind anyone else of this?
(I found the images over on http://www.jamesbondmm.co.uk/)
Attached Thumbnails Mutton Chops-ford-mustang005.jpg   Mutton Chops-ford-mustang002.jpg
Old Dec 14, 2008 | 01:22 AM
Diamonds Are Forever! My Favorite Old School Bond Movie.
Partly because of that Mach 1
Old Dec 14, 2008 | 10:38 AM
hi5.0's Avatar
Would it have killed Ford to have integrated those "mutton chops" and made them a painted part of the bumper cap instead of making it part of the lower opening (grill) insert? I see a bigger part to break if that lower corner should get hit... The V-6 front end just looks so much more cleaner and has the painted "uprights" as well - FTW.
Old Dec 14, 2008 | 04:09 PM
Aaron, nice job. Between your chop, and all of Shawn's insisting on how great a design it is, I am finally starting to warm up to the GT front end. I still think the V6 facia looks better overall, but the GT front end does look a little more aggressive which I like too. I also like Shawn's suggestion that you could use vinyl tape to achieve that look, and then you wouldn't even have to get it painted. The vinyl tape might even help with rock chips, as you could replace the tape if it got to looking bad.
tdf017
Aug 5, 2015 10:13 AM
