MT-82 Transmission: V6 vs V8
Another topic of interest...although the 2011 V6 and V8 Mustangs share the "same transmission", both getting MT-82's, they do have differences. I thought it would be nice to have a thread detailing the differences between them.
For starters, I noticed that they have different gear ratios.
V6 / V8
1st: 4.236 / 3.66
2nd: 2.538 / 2.43
3rd: 1.665 / 1.69
4th: 1.238 / 1.32
5th: 1.00 / 1.00
6th: 0.70 / 0.65
I think they are also using different clutches. And though I have never seen it discussed, I seriously doubt the V6 transmission will be equipped with skip-shift.
A side note: Going back to my inquiry about how a 390 lb/ft engine could be used with a 375 lb/ft rated transmission, after doing some searching, I found a possible explanation -- the transmissions are probably rated based on their weakest link, and the 375 lb/ft may be for the overdrive gear which will probably never see the full 390 lb/ft of torque for extended periods. Not sure how fast you would have to be going to be at over 4k RPM in 6th. That, and the ratings are probably somewhat conservative to begin with.
V6 / V8
1st: 4.236 / 3.66
2nd: 2.538 / 2.43
3rd: 1.665 / 1.69
4th: 1.238 / 1.32
5th: 1.00 / 1.00
6th: 0.70 / 0.65
V6 / V8
1st: 4.236 / 3.66
2nd: 2.538 / 2.43
3rd: 1.665 / 1.69
4th: 1.238 / 1.32
5th: 1.00 / 1.00
6th: 0.70 / 0.65
V6 / V8
1st: 4.236 / 3.66
2nd: 2.538 / 2.43
3rd: 1.665 / 1.69
4th: 1.238 / 1.32
5th: 1.00 / 1.00
6th: 0.70 / 0.65
S197 GT Coyote and S197 V6 Mustang transmissions
The manual transmissions for the V6 s197 and the s197 coyote GT, are different. I purchased a transmission for a good price and was told it absolutely came from a 2012 GT.
It did not!! We only found out about it after taking it apart and
seeing the differences in the housing its self along with the
gears and shafts.
gears and shafts.
gears and shafts.
gears and shafts.
Yea, imagine that. That what I might add to any of these posts might actually help some one looking for answers or heres a novel idea....why dont you try and spend your time trying to help other folks instead of trying to be the smartest guy on this forum. Clearly your not. After all your comments you contributed absolutely nothing. I hope you at least made yourself feel a little better about your crummy life in your moms basement, or you crapy marriage and your dead end job or there might be that your jealous that some of us here actually want to do great things with our cars. And don't really have time for morons like you, because we are to busy actually completing our visions for what we want to acomplish with our Mustangs. Honestly if you feel the need
to add a meaningless retort, or more senseless ramblings.....
Dont. This is not really an open ended discussion. It is however, my comentary on your apparent lack of brain power
and dismall hope for some sort of intelligence. Basically buddy. There is no real need to hear from you ever again.
David Young (9/12/19)
I guess you are just a little butt hurt cause he didn't say
"DING DING DING" we have our weekly winner for waking up the oldest thread from the past, 9 years
![Cheerleader](https://themustangsource.com/forums/images/smilies/cheerleader.gif)
![Firedevil](https://themustangsource.com/forums/images/smilies/firedevil.gif)
![Shower](https://themustangsource.com/forums/images/smilies/shower.gif)
![Welcome2](https://themustangsource.com/forums/images/smilies/welcome2.gif)
What Siber Said. We like Kyle.He has more real world miles on his Mustang than most of us dream of. Respect from Germany. Try getting the right P/N next time fool.
Siber Express (9/10/19)
Received 2,226 Likes
Simply refuse to be offended is my mantra!
![Yes](https://themustangsource.com/forums/images/smilies/yes.gif)
That's what I thought too. The 3.7 V-6 uses a manual trans that is unique by the fact it has a very unusual bellhousing and bolt pattern. As far as I can find it is the only manual trans that will bolt to the Ford F150 3.5L Ecoboost engine. Someone please check me on this.
Randy
Randy
I thought the hardest gear on a tranny was first gear do to the torque multiplication. Normally, you see the torque rating go up as first gear gets taller. I would expect the GT tranny to have a higher torque rating than the V6 tranny do to the gears. Maybe 375 is for the V6 and the GT will be rated for 450 is so do to taller gears?
So someone please debunk the above paragraph. For one I suspect that testing is done using a dynamometer not a heavy vehicle.
So here are the differences besides the bolt pattern. The gear ratio are different like you posted. you can put a complete GT gear set in the V6 housing. Problem in doing so is the output speed sensor will read wrong and you need to tune for it because the GT has more teeth to read than the V6. Currently working getting the straightened out. The difference in the clutch is the GT uses a solid flywheel where the V6 uses a dual mass. The pressure plates are very similar other than i think the GT will have more bolts holes to bolt to the flywheel. The only difference in the disk is the type of spring in the disk hub. Now, you can bolt a GT clutch into a V6 but your throw out bearing will need a .75 inch spacer and you are good to go.
