MotorTrend Dyno #'s
Old Mar 26, 2010 | 08:29 PM
Topnotch's Avatar
MotorTrend Dyno #'s
http://wot.motortrend.com/6659607/au...v-6/index.html
Old Mar 26, 2010 | 08:38 PM
stangfoeva's Avatar
MOTM Committee Member
Motor trend claims 5th gear was too tall....interesting
Old Mar 26, 2010 | 08:40 PM
whysoserious's Avatar
I give up. I just don't get it. If the intent is to use these numbers for comparison while shopping, then they need to dyno the Camaro SS and V6 in 3rd and 4th gear as well to get a more consistent comparison. As consistent as can be with dynos, which has been discussed at length in the other dyno thread.
BlueBossS197's Avatar
And the Camaro gets the shaft.
Old Mar 26, 2010 | 08:44 PM
StangGuy1133's Avatar
Yup, definitely gonna need a Sunday afternoon nap because it's going to be a LATE night!!!!
Old Mar 26, 2010 | 08:47 PM
Fazm's Avatar
just was reading this i love the last paragraph
Of course, the best news we discovered on Friday we can only hint at. We believe those dyno figures just have to be accurate, given the outrageous numbers these two 'Stangs threw down at our test track. But you'll have to check back with us bright and early Monday morning to find those out...
Old Mar 26, 2010 | 08:52 PM
Ltngdrvr's Avatar
Well, apparently their track numbers back up what they found at the dyno.
If that is the case, then mid 13's for the V6 and low 12's for the 5.0 should be in order...
Old Mar 26, 2010 | 08:54 PM
Fazm's Avatar
with the power to weight i show roughly a 13.7 or 13.6 for the v6, and 12.3-12.5 for the gt
again with great traction of course
Old Mar 26, 2010 | 09:21 PM
Ltngdrvr's Avatar
Don't know what calculator you are using or what weight for the car you are using, but this calculator, http://www.allfordmustangs.com/Detailed/619.shtml , shows the E.T. for the 5.0 with a weight of 3700 (with 200 lb driver) and 435 HP as 11.89 @ 114.6!
V6 car would be 13.43 @ 102.17...
Be pretty cool if those were right!
Old Mar 26, 2010 | 09:30 PM
Ltngdrvr's Avatar
It has to be bumping up against the speed limiter.
As soon as a tuner gets ahold of it and removes the limit maybe then we will get a full fifth gear pull.
Fazm's Avatar
that calculator you have is for wheel horsepower, not flywheel horsepower.
Old Mar 26, 2010 | 09:33 PM
Ltngdrvr's Avatar
No, not that I know of, where do you see that it says that?
Old Mar 26, 2010 | 09:43 PM
Fazm's Avatar
common sense
here put in the same numbers to this page
http://robrobinette.com/et.htm
and you will see if you check the real wheel horsepower button with the numbers you are putting in, you'll get the same results, check flywheel and bam, more realistic
Old Mar 26, 2010 | 09:44 PM
Five Oh Brian's Avatar
5.0L GT Manual: 378 rwhp, 3750 lbs (car + driver) = 12.30's @ 112 mph in the 1/4 mile.
3.7L V6 Manual: 267 rwhp, 3600 lbs (car + driver) = 13.40's @ 102 mph in the 1/4 mile.
Old Mar 26, 2010 | 09:58 PM
PTRocks's Avatar
Old Mar 26, 2010 | 10:06 PM
wjones14's Avatar
I'm just giddy right now.
I remember looking forward to the Camaro reviews after all the hype and anticipation, and despite my last three cars being Mustang GTs, I was actually considering a Camaro... until the reviews came out, and the car seemed somewhat underwhelming overall - powerful, solid, and fast, yes, but so many low-to-mediocre qualities too; such as being too heavy and too big, poor outward visibility, relatively cheap interior, quality control issues, etc. Possibly nitpicks, but still, a little less great than anticipated.
On the other hand, I'm anticipating the 2011 Mustang reviews even more, and this one here is saying the car is better than expected!
Old Mar 26, 2010 | 10:41 PM
Red Jay's Avatar
if thats true then GOOD GOD we'd have a STOCK Mustang GT that runs **** near high 11s
Old Mar 27, 2010 | 02:01 AM
1trickpony's Avatar
I'm pretty sure you can get a GT into the 11s with minimal mods. Biggest issue I see is traction.
Old Mar 27, 2010 | 06:36 AM
Falchion's Avatar
Wow! This is really good news. Thanks for posting!
Old Mar 27, 2010 | 06:54 AM
MattR's Avatar
So, If the GT is putting out numbers like this and its still around 150 - 200 lbs lighter than the GT-500 what do you think the GT-500 is going to throw down on the rollers and 1320'?
