Largest 15inch MT street radial?
Old Sep 3, 2012 | 08:27 AM
89LXvert's Avatar
Whats the Biggest Mickey Thompson Street radial can I fit on 2012 stang? Or should I just go with 275/60/15? Im ordering 15 inch wheels.
Old Sep 3, 2012 | 02:06 PM
SoFlaBoss's Avatar
I know that 15x10 Weld RT-S wheels with M/T ET Street Radials, part# 3755R will fit, which are P295/55R15s and 27.8" tall. The 295/55-15s are probably the biggest tire that will fit without removing the bump stops. It also helps that I have an adjustable panhard bar to center the axle perfectly, thus giving the most clearance.
Old Sep 3, 2012 | 06:55 PM
89LXvert's Avatar
Thanks for the reply! Very helpful. What sway bar and panhard bar did you go with? Your car looks great with those wheels! Thanks for tips I do plan on ordering swap bar relocation brackets.
Old Sep 3, 2012 | 08:12 PM
SoFlaBoss's Avatar
You're welcome. My rear swaybar is a Steeda 1 1/4" tubular adjustable bar, and my adjustable panhard bar is a J&M aluminum that I got from American Muscle. I'm very happy with both. However, adjusting the J&M adj panhard bar is a little difficult because the adjustment is on both ends, so you may want to consider that.
Old Sep 4, 2012 | 01:02 AM
rick0202's Avatar
Can you tell me a little more about sway bar relocation brackets? Do they work work any sway bar?
Old Sep 10, 2012 | 07:52 PM
SoFlaBoss's Avatar
Normally they do work with any swaybar. However, they do not work well with a regular Boss's OE 25mm swaybar.
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
Cdvision
Sep 5, 2015 05:22 PM
