JUST INSTALLED ROUSH SIDE SPLITTERS
Old Feb 20, 2014 | 06:50 AM
B's 5.0's Avatar
Originally Posted by Gtstyles2
Subtle yet noticeable mod, it definitely helps the flow of the car when having a front lip
Originally Posted by Last1
Looks great! I have these as well as the rear and they are extremely light. Only issues I have is keeping them clean.
I shall find that out soon enough when I do my spring cleaning.
Originally Posted by Stage_3
I think they look killer.
But then again,...........I may be biased. lol
Cannot imagine why.
Originally Posted by GT50GO
Looks great, I've been back and forth on getting these but every time I see them I'm swaying more towards getting a pair.
Pull the trigger you will not regret it.
Originally Posted by RubyRedMCA_Beast
I think they'd look great on your car.
I'm on the fence about getting them as well.
Old Feb 20, 2014 | 07:02 AM
B's 5.0's Avatar
Originally Posted by Cristoff
Yeah, I don't do subtle very well at all.
I'm guessing yours is a V6? This would be a great upgrade to your front end and overall look to your theme
"NO" mine is a 2013 GT 5.0 the same Mustang Roush uses to transform them into Roush Cars.
Originally Posted by 14rs3roush
Tony, you may be a little biased but rightfully so...I just installed the side and rear splitters on mine. I like the little extra protection they provide and the look is very nice.
I also installed the Nav-TV backup camera setup...very nice.
Originally Posted by dusman59
It was the second mod I did. I wanted some protection from the sticky Brembo tires that pick up everything. The better looks was a bonus.
true
Originally Posted by featurecar50
Do you have to install these by drilling any holes? Or do they just clip on. I would like some protection from stone chips but really do not want to drill any holes, any suggestions?
As stated by members below, very easy install. Here is the video:
U have to make 5 holes on each side. It wasn't bad it all and I cringe very easily
Originally Posted by Horspla
The holes are drilled into the bottom flange of the plastic rocker and are non-visible if you eveer decide to remove the splitters. No harm, no foul, no downside to adding them.
John
Old Feb 20, 2014 | 07:37 AM
Bentnail's Avatar
They look quite nice....
Old Feb 20, 2014 | 07:42 AM
B's 5.0's Avatar
Old Feb 20, 2014 | 11:04 AM
pressman43's Avatar
They look awesome too me.
Old Feb 20, 2014 | 02:10 PM
B's 5.0's Avatar
Thanks.
Old Feb 20, 2014 | 02:20 PM
Bocefus's Avatar
Why make a replica ?
Old Feb 21, 2014 | 07:09 AM
B's 5.0's Avatar
(1). Replica= $44,000.00 including Supercharger
(2). Roush = $68,000.00
(3). Difference of $24,000.00 in my pocket
(4). Because I can.
Old Feb 21, 2014 | 11:43 AM
Bocefus's Avatar
Originally Posted by B's 5.0
(1). Replica= $44,000.00 including Supercharger (2). Roush = $68,000.00 (3). Difference of $24,000.00 in my pocket (4). Because I can.
. Fair enough. I was just curious
Old Feb 21, 2014 | 11:49 AM
B's 5.0's Avatar
Thanks, that is what this forum is about asking questions and getting help and many other good idea's.
Old Feb 21, 2014 | 12:09 PM
ThrustangFiveO's Avatar
I have the roush effects around the bottom of my 5.0 and I couldn't be happier with the look. However I had to reinstall the drivers side one because it wont seem to push towards the back of the car far enough to hug the factory mud flap mold behind the front tire. And it did it again. So there's a noticeable gap under the front of the splitter were its contacting the mold and the tape is visible. I think i got a defective splitter with the holes drilled a little off. Gonna have to take it back off when I have time and modify it to fit.
Anyone else have any issues?
Old Feb 21, 2014 | 02:25 PM
B's 5.0's Avatar
Did you make sure it was lined up correctly? I actually had to cut off about a 1/8" off the rear of mine on both sides because it was pushing on the rubber, but I only had to cut the splitter partially in the back were it cannot be seen, Another words not all the way to the 3M tape. Just behind the Rocker Panel
Old Feb 21, 2014 | 02:55 PM
Gtstyles2's Avatar
I actually just ripped off those inner "mudflaps" if u wanna call them that. Don't see what type of purpose they served, they were in the way
Old Feb 21, 2014 | 03:22 PM
B's 5.0's Avatar
Ha! Ha! yeah, either way will work, but what I had to cut off was not very much at all. Just a little bit wider then a tooth pick and shorter, just used a dremel tool.
Old Feb 22, 2014 | 06:16 AM
Yup, took off those factory mud flap guards on the back off the rocker panel. Lined it up as perfect as possible but i still believe the roush splitter holes are slightly off. Ill figure it out. Its just a hassle.
Old Feb 22, 2014 | 07:39 AM
Looks great! I was debating them before, but would have to get the full front and rear treatment of I were to get it. Also am happy with her current looks at the moment.
Old Feb 22, 2014 | 08:44 AM
Gtstyles2's Avatar
That's actually what made me hold off, the 10-12s don't have a side splitter option for the rear. I heard Classic Design Concepts can probably give u that option if u call them direct. It's off of the RTR rear valance and they may be able to sell separate, but it ain't cheap -_-
Old Feb 22, 2014 | 09:59 AM
B's 5.0's Avatar
I do not understand that. The Roush splitter has 8 square tips that fit in the 8 square holes in the Rocker Panel. How can it not line up? If so I would send it back where you bought it from and have them send you a new one. Did you check the splitters on the bottom side? they are marked LH and RH.
Old Feb 22, 2014 | 12:41 PM
Getportfolio's Avatar
Exactly, those need to be removed before instal. Sorry just saw this. They will warp the splitters when left on.
Old Feb 22, 2014 | 01:36 PM
  #40
B's 5.0's Avatar
I do not understand that. Not saying your wrong. The Roush splitter has 8 square tips that fit in the 8 square holes in the Rocker Panel. How can it not line up? If so I would send it back where you bought it from and have them send you a new one. Did you check the splitters on the bottom side? they are marked LH and RH.
Do they look like this. These are the Roush splitters each one of those 8 tips on each splitter goes up into the Rocker Panel:
