Interesting review on the 5.0 (dynoed 381 rwhp - stock & review and photos)
I saw this post in the Boss section and thought I would pass it on here.
http://autospotters.wordpress.com/20...80%93-finally/
Originally Posted by Ltngdrvr
Doesn't anyone check their facts when they write stuff like this?
His Ford HP numbers were wrong on both engines quoted.
Got the chebby and dodge numbers right though.
Quoted the factory ratings as 314 and 414 for 2010 and 2011 instead of 315 and 412 that they actually are.
Jeez, the 15% internet correction factor needs to have a stake driven through it and crucified up on a cross left to hang in the hotest driest spot on the earth so it can suffer the rightful death it so richly deserves.
I really wish Ford would release some effciency data on the new drivetrain!
While prohibitively expensive, it would be nice to actually see somebody pull a 5.0 from the car after running it on a chassis dyno and then hook it up to an engine dyno with corrected data to see how things shake out. (in as installed condition meaning stock computer and flow path through out. Typically magazines that do this type of thing install some dyno headers and exhaust along with a modified intake path using a controller thats been set for max power and call it "stock").
I'd be willing to bet some real money that the powertrain is only absorbing down around 10-12% maybe.
Nitpick aside cool article.
Ford racing took a 5.0 to Horsepower TV and they put it on the engine dyno. It did have some experimental headers and what looked to be high flow cats. They might have put the ford racing tune on it, but it had a stock intake manifold, intake, and throttle body. It made 468HP @ 7300rpm. I wish they had tested it 100% stock.
And this also corroborates--they use a 11-13% differential.
http://blogs.insideline.com/straight...ang-gt-50.html
the real output of every 2011gt is 416hp SAE. 412 is the 1 percent allowed. its not underrated or overrated. that number is a random new engine off the assembly line.
my car didnt dyno 395 stock. it dynos 398 with mods. that car has an aggressive non production tune on it.
the factory stock tune is to allow warranty issues to be minimized. clutch failures, rear end failures, and transmission failures.
The article also says....
I'm pretty sure the 94/95 said GT/5.0 on the side although it was a different logo than the plain "5.0" emblem. I could be wrong though??
1993 was the last time we saw the 5.0 badge on the side of a Mustang.
Originally Posted by 944withnos
Well I looked through some pics and it looks like the early sn95's had a plain GT/mustang emblem and then they went to the GT/4.6 emblem....Sorry got them mixed up.
Guys did an engine dyno and got 465hp! Could this be true?
I don't know what to believe, but every single dyno I see seems to point to 430-450hp.
http://www.onlymustangfords.com/coyo...dyno-test.html
All of these niggling little details are important when trying to get an idea of what a factory installed engine can do. That test could have been an idealized situation (much like the glamor ratings produced by manufacturers in the 60's) meant to show off what an unrestrained and maximized stock powerplant can do.
