Immediate-sudden a/c issue
Old Jul 29, 2018 | 09:48 PM
junkman9096's Avatar
Legacy Tms Member
I went for a drive today and about 1/2 hour into it the a/c just stopped blowing cold air. Fan worked ok but no cold or even cool air. Normal/max/recirc nothing. If it was just needing a re-charge I would have thought it would gradually gotten less efficient, not stopped "cold"-so to speak. I've had it over 5 years and don't recall if it had ever been serviced, so likely it hadn't. Was like stepping back to the '60s except for no wing windows. Also its been over 95 for 20 of the last 29 days and 102 at the time it failed. So, are there any weak points in the system that I should have them start looking at? 5.0 GT with a/t.
Old Jul 29, 2018 | 11:11 PM
Mr. V's Avatar
When it happened to me, the compressor basically grenaded and killed the system. My car was 5 years old with 78,000 miles. I needed a new compressor, condenser, dryer, and all the lines flushed. It sucked.
Old Jul 30, 2018 | 07:46 AM
Legacy Tms Member
Oooh, not good. I'm at 5 years 4 months and 82k miles. I'll start calling this am. Fingers crossed.
Old Jul 30, 2018 | 02:34 PM
dusman59's Avatar
Just had mine fail yesterday. I was running 75mph with outside temp around 110. Last week it was even hotter. I have a quick reacting thermometer at the center register and the A/C clutch was cycling between 44-° and 40°. The clutch failed. I usually do all my own work but its too hot to do car work now. I'm having the compressor changed out also as it comes with 2 year warranty unlimited miles including labor. I know there have been many failures between 30 and 45k miles. Here in AZ these systems work extra hard. If you got 80k plus count yourself lucky. I think the parts aren't as good as they use to be.
Old Jul 31, 2018 | 07:44 AM
Legacy Tms Member
Its beginning to sound of a theme. I also was running about 75mph and outside temp was 99-102. Its been a warm streak in a warm area. July has seen 22 of 31 days over 95, mostly over 100. Goes to the shop this am. Ford dealer couldn't get me in before Wed afternoon. Going with a trusted independent.
Old Jul 31, 2018 | 01:31 PM
Legacy Tms Member
Bingo! $1K and hopefully back on Thursday.
Old Jul 29, 2019 | 12:28 PM
03GTPNY's Avatar
This sounds like exactly what I am experiencing! CRAP!
JeffreyDJ
Dec 3, 2014 11:28 PM
Zastava_101
Nov 23, 2011 07:30 AM
crescent_wrench
Nov 2, 2011 06:35 AM
Reminisce
21
May 27, 2006 05:13 PM
40thponygirl
1994-2004 V-6
Mar 12, 2006 04:14 PM
