Illuminated Sill Plate Dimensions
Old Jun 12, 2015 | 09:30 PM
wystewart's Avatar
If someone would be so kind, I am in need of the dimensions of the ford illuminate sill plate, for the flat portion with the embedded metal and lighting.
I am trying to figure out if I can fit this to a 1998GT (with modification) by cutting off the U shaped portion and essentially use only the flat portion.
But I have a sneaking suspicion that the sill of the 98 is narrower than the 2005-14.
I would really appreciate it if someone could provide the dimensions. Thanks in advance.
Old Jun 14, 2015 | 07:04 PM
rick57's Avatar
sill plate size
the whole thing is 30 by 2 1/2 just up to the u shape over the door opening
the metal part were the lettering is 14 by 1 1/2
Last edited by rick57; Jun 14, 2015 at 07:10 PM. Reason: realized he wantd differe dimension
Old Jun 15, 2015 | 06:07 AM
wystewart's Avatar
thank you so much!! The sill on my 98 is 2" wide so these would need more trimming than I hoped for.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Good Times
Aug 29, 2015 10:18 AM
spqr
Aug 10, 2015 01:37 PM
