Idle issues in neutral
Old 8/20/21 | 02:38 AM
Iparris's Avatar
I’ve got a 2011 mustang GT with a boss 302 and a live wire sct tune (tuned by a performance shop) and I’m having issues when I’m in neutral the RPM’s will sure up and down and the car will eventually die on itself! Need help!
Old 8/20/21 | 05:17 AM
Bert's Avatar
that is a pretty common thing but I'm not sure of the exact cure . . . first clean everything (throttle body, MAF sensor, ...) and then it might be good to try the "idle relearn" procedure: disconnect the battery for at least 10 minutes; then with the engine cold, start it and let it idle while it warms up; then turn on the A/C and let it idle with A/C for a while . . . I am not sure of the exact timing for all this, but I think it's something like 5 minutes without A/C and then another 5 with A/C on
Old 8/20/21 | 05:28 PM
Jaryd21's Avatar
What bert said. It could be the MAF sensor. Kine did the same for a little while. I cleaned all of what bert said and then did the relearn and poof it was gone. Hope it helps
Bert (8/23/21)
Old 8/22/21 | 10:59 AM
shaneyusa's Avatar
Bert is spot on. Check the owners manual. There is a process as he pointed out that will train the car to idle properly.
Here is a screenshot...
Bert (8/23/21)
Ryan Duffee
7/5/19 07:18 AM
trackpack13gt
1/2/15 10:50 AM
Betsy2013GT
6/3/13 08:22 PM
firetruck
6/3/12 08:27 AM
Locke62
10/31/11 02:08 PM
