How many of you change your oil by the OLM?
#41
I do this on my two chevy trucks that only get about 3,000 miles each put on them a year and I did this on the 2004 Monte Carlo SS Dale Jr. edition that I traded in on the Mustang. I rarely went 5,000 a year on that car.
Wayne
#42
While they never charge me the full price (I'll have to check but full price is 13 bucks a quart) , oil and filter for my car with a 6.5 quart pan is right around 80 bucks.
#43
I'll go against the grain here.My first vehicle with a monitor was an Avalanche. I started using the monitor with that vehicle.I have been using full synthetic for many years and have several friends who are Amsoil dealers, another who is an engineer with Mobil and know an individual who works with maintenance at Schneider trucking.
Changing your oil on a short periodicity is not wrong, but you're probably wasting money. Major trucking firms like Schneider change the oil every 100k miles. Most vehicles recommend longer miles between changes since engines are built so much better and fuel injection reduces the amount of fuel contamination in the oil. The Amsoil guys recommend taking oils samples and replacing the oil when the sample indicates riding contaminants. They do replace filter when reaching the recommended mileage. My old 97 Taurus was msintained this way and has over 150k and burns no oil and has had no valve or cylinder issues.
It may not seem like it but a short drive cycle in stop and go traffic can be considered a severe duty environment as the vehicle doesn't have time to warm up fully and this is when the vehicle experiences to most amount of wear.
A vehicle experiences virtually no wear when warmed up with fluid temperatures stabilized and cruising at a steady RPM on the highway, same way with tires to a lesser extent (I've seen people double the mileage warranty on performance tires due to long commutes on the highway).
Stop and go traffic in the city is hell on everything from the oil to the brakes.
#44
Do you think Ford or any of the manufacturers for that matter that have this type of system, did oil analysis while developing this system to verify that the vehicles could go that long on oil changes?
#45
I currently use Motorcraft full synthetic and filter, changed every 5000 miles due to the adverse weather conditions the car is driven. Really hot in the summer, and extreme cold in the winter. So, Spring and Fall or 5000 miles.
None of the Fords including my Mustangs and the 2013 SHO have used a drop of oil. And, I apply the same criteria to my wife's 2013 Jeep GC. Again, no engine problems and this is her 6th GC.
#46
I do believe Ford, and the other engine builders have tested the vehicles using the criteria set in the IOLM. Why? Because they warranty the drivetrain for 5 years or 60000 miles, or in my case 7 years or 100000 miles(ESP). In driving, all over the world (13 years overseas with the AF)and another 32 years driving in the States, both for pleasure and in a GOV, I have never had an engine failure. That includes driving a Mustang, in Germany on the Autobahn, every day at better then 100 mph for at least 30 minutes each way to work.
Wayne
#48
Sorry for the slow response, but I just saw the post. I have my oil changed at the dealers. They are great, and take good care of the car. Plus side, I have never had a warranty problem since the records are all on file with them. I have the same service advisor when I go in and he knows me by name. I used to do the changes myself, but found the dealer does good work, so why not. I just wait and drink their free coffee.
#49
No problem. I still find it hard to have someone else do what I can do myself plus I can usually get it done quicker myself versus having to wait at a dealer. I also keep very detailed service logs plus keep all receipts and I've never had warranty issues with any vehicle I have owned. Thanks again.
Wayne
Wayne
#50
I like to do it myself and I always clean the undercarriage while i got it lifted over my head and paint the bare metals they left everywhere from factory. Nobody else will take the care I do.
#51
Yeah, I'm not doing all that now. Lmao. Paint the bare metals. Don't care about that now. Lmao
#52
#53
I don't use the monitor either. I change every 5K miles. I currently have 12K miles on the 2012 GT, so I've only changed it twice. The dealer recommended their synthetic blend. I wasn't sure what that was, but I went along with their recommendation. Should I have opted for something else?
I think my car uses about a quart every 5K miles. It's currently at about 12,500, and my oil level is halfway between the dip stick dots. I'm guessing that's a half quart. If not, someone correct me. Also, I'm not sure why the Mustang uses oil. Is that common in performance cars?
#54
i normally change at 30%-40% life left. the OLM is programed to go by temperature, warm up time, rpm, engine load, and probably some other stuff. its more than safe to go by it instead of doing the 3k-5k changes which are really wasteful. when i change it the oil still looks pretty good and isnt that dark at all. i always use royal purple oil and filter. kinda pointless for a DD but i like the chemicals that they use better than most other companys.
#55
Wayne
#56
I did the differential and all that before it rusted but yeah pieces that have I sand down then spray it. I use the VHT suspension paint, it's great stuff. Used it on all my restores so I've always got it around
#57
Wayne
#58
Thanks for the info. Mine was already rusted when I got the car as it had sat on the dealer lot for about six months before I bought it. I would like to paint all of the rusty stuff but didn't know if I could get enough of the surface rust off to let the paint stick. Did you mask off any of the brake lines or just painted over the top of them? Did you put on a primer first or just the VHT paint? Wayne
