Help me to clarify
Old Sep 13, 2010 | 06:39 PM
Praetorian730's Avatar
Help me to clarify
The tpms on the 2011 uses the band sensors, or valve, i was told it was band mounted. Im hearing from someone else now its suppose to be valve?
Old Sep 13, 2010 | 06:42 PM
Ltngdrvr's Avatar
All Fords went to valve stem mounted sensors in 2010 MY.
Old Sep 13, 2010 | 06:46 PM
karman's Avatar
New ones have valve stem
Yup.
Old Sep 13, 2010 | 07:07 PM
Ok fair enough, follow up question. If someone has an 07 and wants a set of wheels (with the valvestems), what would be needed in order for them to work right. Or i guess what im asking is how much is involved
Old Sep 13, 2010 | 07:11 PM
orange3.9stang's Avatar
The Wheels are all interchangeable, but '07-09 Mustangs need the band style and '10-11 Mustangs need the valve stem style.
There are probably a many variations of each style too (for different auto mfr's), so make sure you find sensors that are compatable with the particular vehicle you are mounting the wheels on.
Also ... on an '07-09 Mustang, you can just use regular Rubber Valve Stems that are pretty cheap & plentiful at any auto parts store or the tire shop that will be mounting them for you.
Doug
coolkilled
May 28, 2015 06:43 PM
SINBUSTER007
Apr 28, 2015 05:20 PM
georgeb5060
1971-1973 Mustang
Feb 15, 2015 07:18 AM
