GT500 suspension on 2012 5.0 with Brembo???
Old May 26, 2011 | 02:07 PM
mtnbikefuel80's Avatar
I went into the dealership the other day to listen to a Roush and Shelby exhaust and was told that the 2012 5.0 with Brembo brake package runs the same suspension as the Shelby. Has anyone heard this? Is this true?
Old May 26, 2011 | 02:08 PM
Overboost's Avatar
No. I was told by a Ford engineer that the suspension is unique to the Brembo package. Basically, a 2011 Track Pack.
Old May 26, 2011 | 02:17 PM
CaptDistraction's Avatar
I believe the rear control arms are the same. There's some possibility of the bars being from an older GT500, but I've yet to hear conclusive evidence to that. the springs are definitely unique to the BBP as well as the dampers.
Old May 26, 2011 | 02:32 PM
druice's Avatar
Are there any shared components between the BBP and a base GT? I recall the BBP having stiffer springs at least.
Old May 26, 2011 | 05:46 PM
Okay, Yeah I remember reading that the suspension componenents were different for BBP but i couldn't find out what exactly the changes were. I was told by the person at the dealership that 2011 5.0 BBP didn't have GT500 suspension but that 2012 BBP does. Didn't know what to believe
Old May 26, 2011 | 07:28 PM
MRGTX's Avatar
Bbp vs GT500 on an autocross course...which would you put your money on?
Old May 26, 2011 | 08:18 PM
beerbarrel's Avatar
I can tell you without a shadow of a doubt that the brembos have silver lca's while the standard suspension's are black. At least that is the difference I can see between my wifes car and mine.....lol....other than that anybody's guess is mine.....
Old May 27, 2011 | 07:26 AM
99mstng's Avatar
Does it look like the brembo car is a bit lower than the stock GT suspension? I really wished the BBP dropped the cars at least a half " as the GT sits too high. IMO
Old May 27, 2011 | 08:32 AM
beerbarrel's Avatar
Actually, to me, the Brembo car looks like it sits a little higher. I would measure if for you but at the moment I'm in the Persian Gulf and it will be some months before I get home.
Old May 27, 2011 | 10:43 AM
I agree, I don't know if its the wheel/tire height combo or if the springs sit taller, but the perceived ride height of the BBP is indeed taller than that of other mustangs.
Being that springs are $200-250 and 2 hours of time, to most its a non issue.
Old May 27, 2011 | 10:59 AM
99mstng's Avatar
Yes but then you need a number of other components to do the drop the correct way . . . which adds another few hundred $ to the total. Not complaining as I will likely drop mine 1" eventually just wish it was lower from the factory.
Old May 27, 2011 | 11:05 AM
For sure (I have a lot of parts in my suspension to that regard).
However, for milder drops with spring rates that aren't too far from factory it seems these cars hold up well (alignment specs and dampers).
The dampers are pretty terrible out of the box, but I just meant its not like the SN95 cars where if you didn't have C/C plates, bumpsteer kits, relocated rack bushings, reset pinion angle, new shocks/struts, shortened endlinks for sways, etc... the car would become fairly terrible when lowered.
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
earl610
Sep 6, 2015 05:48 PM
Cdvision
Sep 5, 2015 05:22 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
