Grille emblem question
Does anyone know if this larger grille is a stock part for a 2013 V6 base model? There are no engineering marks or numbers on the larger of the two, or upper grille. Nothing, nada...
The reason I ask is because I'd like to find an emblem for it, specifically the three bar, running horse emblem that usually sits off to the driver side of the grille.
Does anyone know of a source or part number for one that might work?
Thank you,
Alan
Thank you,
Alan
I've attached a link below for Ford OEM Parts Online... This should provide you with the stock part numbers...
https://ford.oempartsonline.com/v-20...and-components
I think That is a Cal Special Set!
https://www.ebay.com/itm/16695615414...Bk9SR4LqhemyZQ
I think This Will Do The Job. Look At The Pics For Mounting on The $90.00 One!
Notice The FORD Drawing Pic! OMG! What a Joke!
Dr3z-8a224-A
https://www.ebay.com/sch/i.html?_nkw...om=R40&_sop=15
Nuts For Emblem W709389-S438
https://www.fordpartsgiant.com/parts...tra2=&filter=()
KC
Dr3z-8a224-A
KC
Had a Similar Thread With an MCA Car! Has Install PDF Might Be Helpful!
https://themustangsource.com/forums/...-grill-551537/
KC
KC
Ford part
Is it me, or does it look like Ford expects you to buy a backer of some type that the emblem then attaches to?
A few emblems look to have a black plastic backer with long shafts on them to accept the push nuts, but one emblem has what looks like a flag that hangs off the lower corner. Never thought this would be this confusing or expensive.
Your Best Buy For a Factory Setup is This & Two Nuts!
https://www.ebay.com/itm/16711962535...Bk9SR-z4jaKzZQ
https://www.fordpartsgiant.com/parts...9389-s438.html
Now You Can Go On The Cheaper Route & Use One of The Aftermarket Setups That Utilize a Fender Emblem, Base & Screws! Position Brackets & Stick Emblem! EZ Deal! Need Screws Positioned So Brackets Wont Wiggle! 4 Screws Would Do The Deed Nicely Or Some Inserts To Go In Grille Honeycomb!
3d Carbon Setup Was Like This! I Think it Used 99-04 Smaller Pony! I Think They are Discontinued!
https://themustangsource.com/forums/...4/#post5330702
Get Yourself The Emblem You Like Say an 05-09 Fender Emblem {larger} and Two Flat Straps and Make YourSelf a Bracket. Does Not Have To Be a Form Fit!
Here is a Mock Up Of That Style on My Gt/Cs as Well! {NOTE} I Actually Prefer The Pony Running Towards The Driver Like This!
https://themustangsource.com/forums/...8/#post7084470
Cheap Generics Go For $20.00 a Pair!
https://www.ebay.com/itm/15501329661...Bk9SR87526OzZQ
KC
KC
05stangkc
Ford OEM Parts {Oem Ford Parts Information & Links}
Jul 31, 2022 12:53 PM
tdbrown75
05-09 Exterior Modifications
18
Nov 16, 2007 05:32 PM
