Fuse for rear center brake light?
I just noticed the center mount brake light is not illuminating. The regular brake lights/turn signals work fine. Looking in the owners manual I do not see a fuse labeled for that light. Does anyone know if it's tied in with another function? I don't mind climbing down there to check but I'd like to know what to look for first. Any assistance will be greatly appreciated.
Kevin
2011 V-6 Premium Auto
No mods
Kevin
No mods
You have a single Yellow wire with a Grey stripe that runs back from the Body control Module. I would find that wire in the harness in the trunk and see if it has power.
You can also take the liner off in the trunk and test the light with a 12 volt source to make sure it is good.
http://iihs.net/fsm/?dir=710&viewfil...rd%20Lamps.pdf
