FR Adjustable Suspension Help
I have the assembled FR adjustable suspension kit and plan on installing myself. The kit includes caster/camber bolts but the strut mounting holes are not slotted. I remember seeing an instruction sheet from FR on a website somewhere on which holes to grind out and by how much. Does anyone have a link to this sheet?
Scott
Scott
I reused the stock bolts without issue. Camber was 1.3 on both sides. The strut mount has some play in it to adjust a little before the 4 top nuts are secured. The slots are not needed.
Did you get an kit instruction sheet? Pm me your email if you didn't and need it. I can email it to you.
This is in the shop manual. I forgot about that.
http://iihs.net/fsm/?dir=725&viewfil...0-%20Front.pdf
http://iihs.net/fsm/?dir=499
Sep 16, 2015 06:44 PM
