DriveShaft question
Old Oct 15, 2013 | 08:48 PM
wentw1tj's Avatar
DriveShaft question
does the gt 5.0L use the same driveshaft as the 3.7L v6 mustang? Can someone please tell me why I am reading so much about the driveshaft blowing up on the 3.7L V6 mustang. Is this happing on the GT 5.0L mustang GT?
Thanks.
Old Oct 15, 2013 | 08:57 PM
TheReaper's Avatar
No, the 5.0 has a different driveshaft.
Old Oct 15, 2013 | 10:02 PM
Brandon302's Avatar
drive shafts blow on the V6's when people get rid of the 120 or so limiter or so it was reported on Autoblog. Seems like the ds isn't meant for mush more rotation. Also the V6 I thought is a solid and the GT is a two piece.
Old Oct 15, 2013 | 10:09 PM
zbrewha863's Avatar
They're both two-piece, but the GT is different from the V6.
Old Oct 15, 2013 | 10:25 PM
CCTking's Avatar
The v6 one is built more for economy, meant to handle lower rotational speeds to keep the rpmʻs from building to fast at higher speeds i think. Thats why when you go past 120ish its rotating faster and longer then originally designed, the joints start gettin off balance causing it to tear itself apart.
The GT ones sre built thicker and joints stronger to handle the much higher tourqe numbers/potential. Which is why they can handle speeds over 150 without any problem.
I wish they both came with an aluminum one piece so we can all really stretch them pony legs out
Old Oct 16, 2013 | 11:32 AM
Ltngdrvr's Avatar
GT shaft is a "True" two piece shaft, as it has two separate shafts with a carrier bearing in the middle, is MUCH stronger than the V6 shaft. The two short shafts in the GT(and GT500) allow for much higher power handling as well as higher shaft speeds. And the GT shaft uses a CV style joint instead of a slip spline to allow for it's articulation. The V6 shaft is also a two piece shaft but the way it works is that one piece slides in and out of the other piece allowing for the articulation of the rear axle.
Back when I had my V6 I was toying with the idea of adapting the GT style shaft to it for a cheap upgrade. I bought the parts to do it but traded the car off before getting it done.
Old Oct 16, 2013 | 11:46 AM
2011 Kona Blue's Avatar
That's one of the reasons I bought myself a one piece aluminum driveshaft on my 11 v6. This way I could stretch out those pony legs. Its sure smooth at 140 mph and climbing.
Old Oct 16, 2013 | 12:18 PM
5.M0NSTER's Avatar
Thanks.
There was a good article on this a while back. I think the V6 has 112mph limiter, and the shaft looses structural integrity around 130mph.
The GT is limited at ~145mph, and I'd imagine the GT drive shaft looses structural integrity closer to 160 or so. But that's just my somewhat educated guess. I haven't seen any GT guys blow out their drive shaft yet.
Old Oct 16, 2013 | 01:30 PM
TheReaper's Avatar
2011 GT is limited to 155 mph.
Old Oct 16, 2013 | 02:05 PM
5.M0NSTER's Avatar
Interesting... I remember reading a statement from Ford that they are limited at "about" 145mph. But it could also be 155mph for 3.15, and if the method of doing it is a rev limiter in 5th and 6th this could very well translate to limitation of ~145 on 3.73 equipped cars.
And if that's the case, the drive shaft should maintain integrity over 170mph to provide a good safety margin. Of course that depends on gearing too, as cars with higher gearing will have higher shaft speed at same vehicle speed.
Old Oct 16, 2013 | 02:17 PM
The v6 rolled 140 mph and kept on pulling. .
Old Oct 31, 2013 | 11:34 AM
RubyTuesday2014's Avatar
Since the GT and the BOSS both use the MT82, then I would assume that they both use the same driveshaft and would be rated for higher torque then the GT can put out. I read that the GT is limited to 147 and the BOSS to 155. The drive train takes the most stress from dead stop. Once in motion, the stress is less. On a two-piece drive shaft(with a support bearing in the middle), the support takes the most stress on initial take off. Basically, the transmission is trying to push the front half of the shaft thru the floor in the back seat. So switching to a one piece switches the stress to the ends. Then the u-joints hopefully will be made stronger to take the extra stress. I have broken the center support mount before...not fun.
So a one piece will still have to have a sliding part on a yoke into the transmission or inside the shaft itself to allow for suspension travel.
Old Oct 31, 2013 | 08:46 PM
TheReaper's Avatar
The 2011 GT 6R80 is limited to 155. My car shuts down when the speedo hits 155 and the Garmin reads 153 mph.
Old Nov 3, 2013 | 12:31 PM
TheDivaDanielle's Avatar
GT with a tune must be free to clear 155mph........ hmmmmmm
Old Nov 3, 2013 | 02:31 PM
TheReaper's Avatar
Yes it is.
Old Nov 3, 2013 | 03:14 PM
Yes it is.
not commenting, after all, Ford watches us.
Old Nov 3, 2013 | 03:22 PM
Womprat's Avatar
Dont know about the new ones but my 2005 was a cv style, no slip yoke, The Shaftmasters I replaced it with had the slip yoke.
Old Nov 3, 2013 | 06:28 PM
Yes it is.
I was under the impression if the tune deletes the electronic speed limitation, then you will void a portion of the warranty that was pertaining to the engine and that the higher speed my break
Old Nov 3, 2013 | 07:12 PM
TheReaper's Avatar
Yes you do according to this.
File Type: pdf
Old Nov 3, 2013 | 07:30 PM
MachRMan's Avatar
I had a shaft masters Aluminum DS on my 2011 v6. Sold it for a 12 GT ad kept the DS. Sent it back to shaft masters and they cut approx. 3" off of it, re-balanced and changed the flanges to match the GT! DS fit perfectly. so they are different in length from v6 to v8 even w the same transmission.
