Drained battery with aftermarket radio
Old Apr 11, 2023 | 08:11 AM
GFW18's Avatar
Originally Posted by Lilward5
Hello. I've replaced the original radio with the Metra 99-5839CH kit. It does everything it is supposed to do. My steering wheel controls needed to be tweaked a little. Since the new installation, my battery dies. The battery lasts for about 2 days before complete drainage. I have yellow to yellow and red to red. Radio was professionally installed, although I am capable of doing it myself.
2014 GT Premium
Has anyone ran into this problem?
Sony XAV-AX200 radio Metra 99-5839CH Turbo Touch kit
Were you able to find out how to fix this?
Old Jun 4, 2023 | 07:34 PM
Hill's Avatar
Battery draining after dash kit install
I had the dash kit from metra 99-5853CH and pioneer stereo installed by a business and ever since it’s drained my battery. The rear defrost button hasn’t worked on the dash since I left the store a week ago. I’ve been doing research and it says the car is looking for sync which is killing my battery. How do I fix this issue. I asked the guy that installed it and he stated it was easy just plug and play. My old factory stereo stopped working but the climate controls all worked. Is there something I should have done before removing unit?
How do I get the car to stop looking for sync
Old Jun 4, 2023 | 08:08 PM
05stangkc's Avatar
https://themustangsource.com/forums/...ompany-549893/
Maybe Helpful!
KC
Old Jun 4, 2023 | 08:20 PM
Hill's Avatar
Did the parasitic test already. Traced it to a fuse that is related to ford sync. Problem is ford sync not seeing the radio.
Old Jun 4, 2023 | 08:31 PM
05stangkc's Avatar
May Try The Resources Shown on the Apim Doc I Added To Post!
KC
Old Jun 4, 2023 | 08:32 PM
Hill's Avatar
KC
looking into it now thank you
Old Apr 7, 2024 | 02:33 PM
MI2QWK4U's Avatar
Is there a corresponding fuse that will disable the active anti theft system?
Old Apr 7, 2024 | 02:38 PM
05stangkc's Avatar
Howdy Doo!
Your Account Was in Limbo! Fixed With a Bogus Birthday! Also Upgraded Your Title!
Lots Of FORD info on Theft System Here!
https://themustangsource.com/forums/...5/#post7079754
KC
Old May 14, 2024 | 07:07 PM
Deftek's Avatar
Is this the fix?
KC
So with the Metra kit, are you suggesting that the document you added, I could show to my installer at my local car AV shop, and then they could pull a fuse that would stop the sync from searching for the radio? Like is that document gonna provide the installer with a solution to the sync problem?
Old May 14, 2024 | 07:25 PM
Deftek's Avatar
hey so with this exact metro radio install kit, were you ever able to figure out how to make it not drain the battery? Aka how to make it stop searching for sync radio? I have a 2012 mustang GT coupe
Please Let me know!
Old May 27, 2024 | 01:02 PM
borjL's Avatar
Please Let me know!
I do not have this kit but after doing a lot of research online before (almost) buying the kit i saw a couple of solutions.
If you have sync, look under the glovebox for the sync box, after you have located it you want to unplug the power cable which is the big fat chunky one all the way on the right (when you’re looking at it from the front). This cable is secured on by a latch so you CANNOT just pull hard, you will break it. It’s an easy disconnect, just press down the little button and the latch will slide over and you will be able to disconnect it.
If that does not work, you will have to pull the sync fuse which i believe is located in the passenger side kick panel. This is the only other solution i’ve seen has worked for some. If that does not work for you i’m not sure what else would be causing the battery drain.
Hondo
Oct 1, 2023 01:01 PM
Ugabulldog83
Nov 1, 2014 12:09 PM
Hondo
Apr 5, 2014 08:04 PM
steevr
05-09 Interior and Audio Mods
Jul 28, 2013 05:27 PM
Pendarus
26
Dec 6, 2007 08:31 AM
