Double adjustable shock settings
Please Help,
Can someone out there please help me, educate me on compression and Rebound? I have double adjustable Viking shocks Part number B226. Were would I set the Comp and Rebound to have no traction and than were would I set them to have the most traction. "My kind of driving would be on the no traction side that is what I am wanting to accomplished." Correct me if I am wrong but for the most traction I beleve you would set the Comp between 0-2 and the rebound to 12-18. I do not plan on ever tracking the car. "drag racing that is" Road course maybe someday. I also have been told to never place the rebound higher than comp, that is why I am scared to do it, if that setting is need to accomplished no traction than that is what I will play with after hearing yours guys input.
Current car setup
N/A 5.0L track pack 6 speed, tuned by Brenspeed with the JLT CAI. FULL BMR suspension, "Upper control arm and mount, lower control arms and relocation bracket's, FRPP 5300-K springs front and rear. M-18000-C GT500 front col overs, turned to the siffist setting" 1 piece aluminum drive shaft. MGW shifter.
Car is also lowered an inch and half, with the BMR adjustable Panhard Bar.
Thanks to all of you.
Current car setup
Sep 23, 2015 03:21 PM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
