Does anybody run reg 87 octane fuel in their 302?
Old Jan 20, 2012 | 09:22 AM
Jersey Monte's Avatar
With the rising cost of gasoline(again) I read in my owners manual that 87 octane fuel can be used with a reduction of HP .
I have been running 87 in mine for about 4 months with no side effects
Haven't goten on it, but car runs surprisingly well getting about 24 mpg
average easy diving, I will probably go back to premium in the summer
Old Jan 20, 2012 | 12:08 PM
kylerohde's Avatar
Same - I don't notice a difference in the least. Guess I might if I was drag racing it but for normal day to day driving, I see no difference. I've kept very close track to see if the mileage is any worse with 87 and I haven't see a noticeable difference, and certainly not enough to make cover the additional $4 or so per tank it costs for 91 versus 87.
Old Jan 21, 2012 | 06:51 AM
MyStang2010GB's Avatar
For the difference in a tank of gas between 87 and 93 I just run the 93. Car isn't a daily driver anyways so a tank can last me a few weeks.
Old Jan 21, 2012 | 08:08 AM
5LHO's Avatar
I split the difference and run 91. Safe everywhere, max power when needed (yeah right on public roads in the winter).
Old Jan 21, 2012 | 12:12 PM
TheReaper's Avatar
I run 93 because we don't have 91 and will continue to do so because I need the 5 extra horsepower.
Old Jan 21, 2012 | 12:14 PM
11SHELBYGT500's Avatar
I think it's 10. lol
Old Jan 21, 2012 | 01:14 PM
jskup1's Avatar
For saving only $3 - $4 per tank, I wouldn't risk it. In my RX8 that required premium, running anything less caused detonation. Especially with ethanol being blended and the reports of incorrect octane ratings, you can't even really trust 87 truly being 87.
Old Jan 21, 2012 | 03:50 PM
kylerohde's Avatar
Since 91 is the highest octane available in many states, the car is optimized for 91 octane. Unless you can only get 93, you're wasting your money using it (of course, if you have been tuned for it, that's a different story.
Hard to argue with that, but I think this motor is infinitely more flexible than that rotary. I've run at least 20 tanks of 87 through mine with zero noticeable difference. Only real difference I've seen is when I was able to find pure gasoline. The car loves it.
Old Jan 21, 2012 | 04:03 PM
2012GTCS's Avatar
Hmmm wonder If they have pure gasoline around me. You got it at a station or a racing spot?
Old Jan 21, 2012 | 07:32 PM
jimmbbo's Avatar
To prevent detonation, the knock sensor system adjusts the timing in response to the fuel octane being used, resulting in a loss of ten HP at the top end.
87 octane is perfectly safe, and IMO is a painless way to save money, unless you just gotta have those last ten HP.
Old Jan 21, 2012 | 10:58 PM
cinque35's Avatar
if sunoco still had 85 i'ld use it.
the little gain isn't worth the big cost
Old Jan 21, 2012 | 11:05 PM
kylerohde's Avatar
Try buyrealgas.com and pure-gas.org - not a lot but still some spots out there.
Old Jan 22, 2012 | 11:13 AM
MustangGTPilot's Avatar
Shame they still put a little lead in aviation gas which is 100. Just back from Dubai and shocked that their "low quality" gas is 95 and regular is 98 octane!!!
Old Jan 22, 2012 | 01:51 PM
2010MustangGT's Avatar
Octane recommendations (5.0L V8 engine)
"Regular" unleaded gasoline with a pump (R+M)/2 octane rating of 87 is
recommended. Some stations offer fuels posted as Regular with an
octane rating below 87, particularly in high altitude areas. Fuels with
octane levels below 87 are not recommended. Premium fuel will provide
improved performance and is recommended for severe duty usage such
as trailer tow.
For Shelby GT500 octane requirements, see the Shelby GT500 Supplement.
Page 292 of your Owner's Manual
Old Jan 22, 2012 | 02:20 PM
SD CALSPCL's Avatar
I have always used Premium, since it is 100% pure gasoline, in the area where I live. Everything else has Ethanol added.
According to a fact sheet, from Ford, with Premium you have the full 412 hp, while Regular will drop that to 404 hp...not even noticeable in "normal" driving.
Old Jan 22, 2012 | 02:23 PM
402 with regular
Old Jan 22, 2012 | 08:59 PM
jimmbbo's Avatar
Since ethanol can be used to increase octane rating... buying "premium" fuel does not guarantee you're getting "100% gasoline"...
"Octane rating does not relate to the energy content of the fuel... It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. Where the octane number is raised by blending in ethanol, energy content per volume is reduced."
The loss in maximum HP is due to the timing changes made by the knock sensing system to keep the fuel/air mixture from detonating...
Old Jan 22, 2012 | 09:04 PM
If its a DD just use the lowest grade you can. You're not going to miss 10hp
Old Jan 22, 2012 | 09:10 PM
93 is more available where I live than 91 is. I actually ran 91 a few times and could hear pinging....so went back to my favorite station and the 93
Old Jan 22, 2012 | 09:12 PM
What????
