Does the 2011 3.7 have an overdrive button or feature?
Do we have an overdrive feature or not. I have a hill assist button but it doesn't say overdrive and it lights up yellow with a car going down. I do notice that when I turn on the hill assist button my rpm's raise just like when one would turn off the overdrive. It seems that my pony has a bit more acceleration power when i hit the hill assist button on since the rpm's get raised but maybe its just me.
Is the hill assist button the same as overdrive if so wouldn't it make sense to turn on the hill assist button when at the track or trying to pass another vehicle for faster acceleration?
In my opinion, the hill assist is for going down long mountain roads in 5th gear so you don't have to ride your brakes and maybe 'over heat' them.
I've experimented with turning on hill assist at the track and it doesn't behave the way you'd think it would. It actually made my car slower in the 1/4. It does hold lower gears longer when not at WOT, but at WOT, it behaves a bit strangely. I didn't datalog, but it kind of seemed to me like maybe it was pulling timing our something which is why my ET's were worst with it on.
1- being on a hill
2 holding the brake seconds for a minimum of 2 seconds
And then the car stays put for two seconds before the brakes release and you begin rolling back.
This is from a tutorial video i watched on fords website. There was no mention of anything else in the works behind this technology.
Hill Assist is a feature that allows your transmission to hold the lower gears for a long time while also engine braking. It's so you don't ride your brakes going down hill.
I wouldn't recommend it while racing. I've had slower lap times and 1/4 mile times when I tested how the hill assist would be.
As db2797 said, I think the PCM retards the timing. I had a stock Scion FRS stay next to me at the 1/4 mile strip the whole way to the finish, I was upset until I realized I had the 'hill assist' future on. I have a GT, so that shouldn't have happened. Next runs were much better with it off.
haha - I gotcha now. sorry for the mixup. I hadn't have thought about this. I had my head wrapped around Hill brake assist and couldn't get past that. yeah, that's definitely a nice feature to have with those transmissions. it definitely does make the vehicle safer just about anywhere you go these days.
I always thought hill assist was a brake application on a manny tranny when you are at a stoplight heading uphill - for people that have difficulty with clutches on hills (and haven't figured out how to use the hand brake).
D (Drive) with grade assist
Press the transmission control
switch on the side of the shift
handle to activate grade assist.
• This position allows for all
forward gears and provides
increased engine braking.
• Grade assist lamp is illuminated.
• Use with driving conditions such
as hilly terrain, heavy loads,
trailer towing and when engine
braking is required.
• To return to standard mode, press the transmission control switch.
The grade assist lamp will not be illuminated
Hill or Grade.
My wife's Edge has "Grade Assist" which is different from "Hill Start Assist" as has been noted. Hill Start Assist applies to manual transmissions and will hold the brakes for an extra couple of seconds when starting on a hill to keep from rolling while engaging the clutch. Grade Assist applies only to automatics... it disables overdrive and changes shift strategy so that the transmission stays in lower gears longer and provides additional engine braking. I used it for the first time on a recent trip to Buffalo while going through the mountains in Virginia and West Virginia. Not only does it reduce dependence on brakes going downhill but it also reduces (almost eliminates) those annoying kick-down shifts going uphill on cruise control. Overall, the ride was much more pleasant with it engaged in hilly/mountainous terrain. Surprisingly, it did not make as much of a difference in fuel mileage as one would expect - maybe 1-1.5 miles per gallon, much of which could be attributed to the terrain anyway.
btw, are you able to manually change a Mustang Auto from 6th to 5th with the shifter? I've not been in a 6spd auto so just wondering why the Grade Assist is necessary vs just putting it into 5th yourself...
My winter car is a 4spd auto and I just take it out of 4th (overdrive) and drop it into 3rd coming down the pass which adds engine braking.
There we go!
