do I need new tunes from AM/Bama?
Old Jul 20, 2015 | 08:10 AM
dohc97's Avatar
I have the bama free tunes for life. I am getting new tires for my Gt. My current tires are Nitto 255/35/20 and 285/30/20. The new tires are MT 275/35/20 and 305/35/20.
Do I need to get new tunes?
Old Jul 20, 2015 | 10:43 AM
DarrenGT's Avatar
You may need to adjust the rpm per mile if your overall wheel heights change. If your device has that option available seperate from the tune you can adjust it. If not they may need to adjust it in the tune and send it to you.
Old Jul 20, 2015 | 11:01 AM
CiniZter's Avatar
as it is free for life, get the tune revised and if you have not tried the new V2 tune from bama. it will be a good time to do that too.
Old Jul 20, 2015 | 11:13 AM
AMWill's Avatar
Former Vendor
Hey Dohc,
Although the car will still run fine, and the speedo will not change by anything major, a revision would be recommended to get it back to perfect and the Bama team will be able to take care of that for you quickly and easily!
Shoot them a call and they can have everything all setup!
Hope this helps.
-Will
Old Jul 20, 2015 | 12:28 PM
dohc97's Avatar
Originally Posted by AMWill
Hey Dohc,
Hope this helps.
-Will
Will,
I ordered the tires from you guys yesterday. Will it be here in northern Virginia before Friday?
Thanks...
Old Jul 21, 2015 | 09:22 AM
AMWill's Avatar
Former Vendor
Will,
Thanks...
Hey man,
I don't see why not!
If the tires were in stock and ready to go they should be at your door today/ tomorrow!
That being said, shoot me over your order # and I'll check up to make sure everything is going smoothly.
-Will
Old Jul 22, 2015 | 04:52 PM
dohc97's Avatar
Will..
I got confirmation from the tire shop that my tires were delivered yesterday.
Thanks..
Old Jul 25, 2015 | 08:50 AM
Bert's Avatar
You can have Bama adjust the tune for the new tires; or you can do it yourself using "adjust parameters" before you-reload your existing tune.
If you want to do it yourself, first look up your rear tires on the manufacturer's web site and find the "revolutions per mile" number. Then go in to your tuner like you were going to load a tune to the car. Go in to the "adjust parameters" screen, find revs/mile, find the number that is closest to the right number for your rear tires, and select it; then go ahead and load the tune.
Old Jul 26, 2015 | 01:15 AM
dohc97's Avatar
I just installed the new tunes I got from Bama. My speedo was off by about 4 miles at 60mph.
Everything is back to normal.
Old Jul 26, 2015 | 08:51 AM
DarrenGT's Avatar
Basically the same as mine was since i have the same tires. My revs per mile had to be set to 750 i think. I did it manually with my sct.
Old Jul 26, 2015 | 09:16 AM
Reminisce's Avatar
This is good to know as those are the tires i have and the tires im switching to on my next tire set.
Also, Cinizer mentioned V2 tunes? What are those? I have Bama tunes in my car from about a year ago.
wallace
Mar 29, 2016 10:09 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
