Diagnosed Transmission Whine Without Disassembling
I took my car in because the transmission started whining in gears 1-4 under acceleration. The car was 4 days old with 380 miles on it.
At first the service manager brushed me off saying "Ford doesn't like to fix things that aren't actually broken unless they make noise for 1,000 miles". And I asked if I could at least have the tech drive my car. The tech actually asked me to drive and show him what it was doing. He said "WOW..." like three times on your two minute test drive and even said "thats so annoying". When we got back he asked the service manager to send in a call to the Ford hotline (some kind of email thing it wasn't a phone call). She said she would call back and let me know what Ford wanted to do. After hearing all the "could not reproduce problem" and "its normal" comments people had gotten from dealers on here, I wasn't too optimistic. I got a call a few days later that Ford wanted them to put some kinda of "chassis scopes" on the car to determine if the noise was coming from the trans or somewhere else and that if it was coming from the transmission they would have to "take it apart". So today I dropped the car off and called at lunch for an update, I was told that they ordered a bearing for my transmission and it would be here tomorrow. I asked how they diagnosed a bad bearing and they guy couldn't tell me, so I figured I'd call after work and try to get the service manager. I talked to the service manager in the afternoon who told me that the noise was definitely coming from the transmission, and they had told Ford. She said Ford told them which bearing was bad, and to take the transmission apart tomorrow and replace it when the bearing comes in. She said it was the #9 bearing (I'm not familiar enough with an MT82 to even know which one that is). This kind of story is contrary to what I have read on the internet so far, and I wanted to share it. Ford acknowledged my whine was not normal, made sure it was the gear box, and even diagnosed the bad part without the dealer even working on my car. I am very curious to see if replacing this bearing fixes the whining noise. If it does this sounds more like a bad run of bearings and Ford is well aware of whats going on, but maybe they don't have traceability as to what bearings made it into what transmissions/cars? Anyway I will update you guys tomorrow and hopefully my car is fixed and Ford is one step closer to a TSB for removing gear whine and maybe even the transmissions that have shifting problems. |
Hope that fixes the whine, not all dealers are bad.
keep us posted!
It sounds to me like you have a good techs at your dealership.:nice:
I called at lunch and the bearing had just got in. She said as soon as he finished the car on his rack mine was going on. She said it still might be this afternoon, but they want to "be very thorough when going through the transmission" to make sure everything else is ok.
I'll update when theres something new. |
The whining is the MT82 for SURE. I swapped for a TR6060 and no more whine.
(loved the sound of the whine though!) |
Originally Posted by unas2k5
(Post 6123389)
1 Attachment(s)
My guess is that they use some form of audio spectrum analysis being that the engine and gears all operate within audable range based on engine RPM.
Every rotating component will have its own frequency. |
Well whatever car was on the rack too longer than expected. My car should get started first thing in the morning and be dont "not too late in the day".
We will see.... |
I am curious about this as well. I have had the whine on my car for some time now so i took it into the dealer and they said the same thing. "Its not normal but the higher ups at Ford said its not bad enough to fix it yet. It needs to get worse before we can make it better."
All I know is that the noise is very annoying especially when i am trying to enjoy some good music and the sound is overpowering it. I really want to get this fixed so i figured i will wait a 1,000 miles and take it back in. |
(Post 6123393)
:pics:
LMAO What do you want pictures of? |
:popcorn:
(Post 6123740)
:popcorn:
lol What are you waiting on? |
(Post 6123751)
Originally Posted by blackgt87
(Post 6123050)
This kind of story is contrary to what I have read on the internet so far, and I wanted to share it. Ford acknowledged my whine was not normal, made sure it was the gear box, and even diagnosed the bad part without the dealer even working on my car. I am very curious to see if replacing this bearing fixes the whining noise. If it does this sounds more like a bad run of bearings and Ford is well aware of whats going on, but maybe they don't have traceability as to what bearings made it into what transmissions/cars? Anyway I will update you guys tomorrow and hopefully my car is fixed and Ford is one step closer to a TSB for removing gear whine and maybe even the transmissions that have shifting problems. The new trannies starting going in on July 25th. New parts: 5th gear - countershaft 6th gear - countershaft 6th gear - output shaft The other half of 5th gear is attached to the input shaft. That part is not listed on fordparts.com at the moment. |
which july 25th? 2010 or 2011
subing
Subscribed
Originally Posted by way2qk4u2c
(Post 6123879)
interesting maybe they think this is the cause of the problem
