Data Logging
Old Aug 28, 2011 | 02:27 AM
blackgt87's Avatar
Data Logging
Finally got around to data logging my 93 octane Bama tune. I was really just looking at knock at first, and trying to figure the software out.
I read somewhere else that the knock sensors pick up a ton when you shift, do they pull timing based on that?
What is the value of the knock sensor representing? Degrees of timing pulled?
I'm a n00b at this so I appreciate all input. I was really just trying to see if the Bama tune was knocking at all.
Old Aug 28, 2011 | 05:43 AM
Overboost's Avatar
If you can, find someone with a DashHawk and set up a screen with knock and spark advance (can't remember what other parameters you might need). You should be able to monitor that in real time and log it if need be.
Old Aug 28, 2011 | 10:43 AM
blackgt87's Avatar
I had my sct plugged into my laptop and I was using live link so I could see everything. I just need to know what the values mean and whats too much and if my tune needs revised.
Old Aug 28, 2011 | 11:29 AM
RedCandy5.0's Avatar
You should be able to save it and send it to your tuner to see what needs to be adjusted if anything.
Sep 8, 2015 10:45 AM
tukatz
Aug 26, 2015 02:06 PM
Detroit Steel
2007-2009 Shelby GT500
Aug 17, 2015 02:29 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
kn7671
Aug 16, 2004 06:38 PM
