Data Logging
Data Logging
Finally got around to data logging my 93 octane Bama tune. I was really just looking at knock at first, and trying to figure the software out.
I read somewhere else that the knock sensors pick up a ton when you shift, do they pull timing based on that?
What is the value of the knock sensor representing? Degrees of timing pulled?
I'm a n00b at this so I appreciate all input. I was really just trying to see if the Bama tune was knocking at all.
If you can, find someone with a DashHawk and set up a screen with knock and spark advance (can't remember what other parameters you might need). You should be able to monitor that in real time and log it if need be.
I had my sct plugged into my laptop and I was using live link so I could see everything. I just need to know what the values mean and whats too much and if my tune needs revised.
Sep 8, 2015 10:45 AM
Detroit Steel
2007-2009 Shelby GT500
Aug 17, 2015 02:29 PM
