Dark Oil
Old Sep 20, 2010 | 06:15 PM
nemosgt's Avatar
Dark Oil
Hi Guys. Using Mobil 1 in my 2011 GT. After one track day, recently changed oil appears dark colored. My '06 remained clear between oil changes. Buddies 4.6 at same track day, clear as the day it when in. Notice a lot of heat when opening hood. While driving, I notice the fan often comes on even under conditions where you would think it shouldn't need to. Gauge reads normal (I know it's an idiot gauge- but just the same--) and no over-flow from the reservoir. Anyone else notice the 5.0 running a bit hotter than the earlier cars or have I a problem coming up. Can you check your oil and let me know what it looks like. Thanks.
Cheers.
Old Sep 20, 2010 | 06:20 PM
2010MustangGT's Avatar
Check this article.
It explains it very well.
http://carfixonline.blogspot.com/200...-it-needs.html
Old Sep 20, 2010 | 06:47 PM
can't go by looks alone!
Old Sep 20, 2010 | 07:57 PM
todd03blown's Avatar
I have never had any car where the oil stayed clear (original oil color at the time of the change) during the change interval.
Old Sep 20, 2010 | 08:18 PM
Onelildude's Avatar
Same here....even in my 08 F150 w/35's the oil never stayed clear or even close to it
Old Sep 21, 2010 | 10:29 AM
orange3.9stang's Avatar
Originally Posted by 2010MustangGT
Check this article.
"A good test to see if the oil needs changing is to feel it in your fingers.(Caution: used oil is toxic and carcinogenic. If you get it on your skin, it could cause problems. Use gloves!) If it feels grity, that is an indication it should be changed."
Tell me this guy (or anyone else for that matter) actually checks for oil "grity-ness" with gloves on ... that's gotta work well !!
Doug
Old Sep 21, 2010 | 01:43 PM
825LTRGT's Avatar
If oil changes color, gets darker, that means it is doing it's job by suspending dirt.
Old Sep 21, 2010 | 01:53 PM
I like this article so much I've been spreading it all over the net.
http://www.nytimes.com/2010/09/11/yo...cuts.html?_r=3
sorry for the Al pic its who I think of when ever I hear/write the the word internet
Old Sep 21, 2010 | 03:02 PM
nemosgt's Avatar
Thanks guys for the replies. I was just getting worried because the engine bay gets so warm I thought maybe the oil was burnt. I don't remember the '06 running so hot.
Thanks again. I'll relax a little now.
Cheers.
Old Sep 21, 2010 | 03:05 PM
nemosgt's Avatar
Ah yes. Our hero.
Thanks Al.
Cheers.
Old Sep 21, 2010 | 04:32 PM
Doug
I'd suspect it's implied with like surgical gloves or painters gloves... very thin, cheap, clear... you could feel almost anything. Not like leather gloves used to pick up slabs of concrete so you don't tear your hands.
Old Sep 21, 2010 | 07:26 PM
hawkeye18's Avatar
>Have to give them all your personal info just to read the article
Old Sep 22, 2010 | 05:45 AM
pops right up for me Jason.
The 3,000-Mile Oil Change Is Pretty Much History
By ALINA TUGEND
Published: September 10, 2010
I STILL remember learning from my father how to carefully remove a dipstick to check the oil level in our cars. It was drilled into me — along with turning off the lights when you left a room and clearing the plates off the table after dinner — that oil needs to be changed every 3,000 miles or so.
Enlarge This Image
Gregory Shaver/The Journal Times, via Associated Press
Kieron Kohlmann changing the oil in a 2007 Dodge Charger in Union Grove, Wis. Changing the oil every 3,000 miles is no longer a good guideline for cars bought in the last seven or eight years, says Philip Reed of the car site Edmunds.com.
Related
I’m not sure what I thought would happen if I didn’t, but I vaguely imagined an unlubricated engine grinding to a halt.
Childhood habits are hard to undo, and that’s often good. To this day, I hate seeing an empty room with the lights on.
But sometimes, we need to throw aside our parents’ good advice. In March, for example, I wrote about how we should relearn the dishwasher and laundry soap habits we inherited from our mothers.
Add frequent oil-changing to that list.
“There was a time when the 3,000 miles was a good guideline,” said Philip Reed, senior consumer advice editor for the car site Edmunds.com. “But it’s no longer true for any car bought in the last seven or eight years.”
Oil chemistry and engine technology have improved to the point that most cars can go several thousand more miles before changing the oil, Mr. Reed said. A better average, he said, would be 7,500 between oil changes, and sometimes up to 10,000 miles or more.
The California Integrated Waste Management Board ran public service announcements for several years about “the 3,000-mile myth,” urging drivers to wait longer between oil changes. Although the information is a few years old, the board has a list of cars on its Web site and how often they need oil changes. The concern is not only the cost to drivers, but the environmental impact of throwing away good oil, said Mark Oldfield, a recycling specialist for the agency.
But the situation is not that clear cut, according to Robert Sutherland, a Pennzoil scientist who works at Shell Global Solutions.
Rather than picking a number, Mr. Sutherland said, he recommends following what your owner’s manual advises. I checked the manual for our 2007 Mazda5 and had to determine if my typical driving included a lot of stop-and-go driving, short distances, extended idling, muddy, rough or dusty roads or really humid or cold temperatures.
Hmm. Yes, to short distance and stop and go. So that meant I should get the oil changed every 5,000 miles. If I did a great deal of longer-distance highway driving, it would be every 7,500.
The different types of driving are usually known as severe and mild (which is also sometimes called normal), Mr. Sutherland said, which seems counterintuitive since most of us probably don’t think we drive in severe conditions. But we do.
The reason, he said, is that if you take a trip of less than 10 miles or so, the engine and the oil are not completely warmed up. And if the oil is still cool, he said, it cannot absorb the contaminants that come from internal combustion as efficiently.
“It’s designed to work best when fully warmed up,” Mr. Sutherland said. “If you’re running to the music lesson, to school, the gym, that’s severe driving conditions.”
Mr. Sutherland said he has a mild commute. “It’s 47 miles, all highway.”
What actually happens if you don’t change your oil? Well, it doesn’t run out, it simply gets dirtier and dirtier. It’s like mopping the floor with a bucket of water and detergent. The water starts out clean, but the more you use it, the filthier it gets. Eventually, you’re making the floor dirtier if you don’t change the water.
Some people remain attached to the 3,000-mile oil change and have a hard time trusting the recommendations in the owner’s manual. If you’re one of those skeptics, you can send your engine oil out to be analyzed. Blackstone Laboratories in Fort Wayne, Ind., one of the best-known places for engine oil analysis, will send you a free kit.
You send back an oil sample and for $25, they’ll tell you all sorts of things about your car.
“We would compare what your oil looks like compared to the average Mazda5 of that year,” said Kristen Huff, a vice president at Blackstone. If there is a lot more lead in my oil than in a typical Mazda5, for example, it means I have a bearing problem, she said.
Her lab runs about 150 samples a day and a fair percentage of those are consumers looking to find out how often they need to change their oil, Ms. Huff said.
“Very often, it is the case that they’re changing their oil too often,” she said. “They do what their dad did with his ’55 Chevy.”
Another way to get a more accurate assessment of your oil needs is to buy a car that has a maintenance minder, like a Honda. A light on the dashboard alerts the driver when the system judges that the oil has only 15 percent of its useful life remaining. The time between oil changes varies depending on the driver and driving conditions.
Related
Honda has used such maintenance minders on most models for at least the last five years, said Chris Martin, a Honda spokesman. Previously, the owner’s manual suggested changes every 10,000 miles in mild conditions and 5,000 miles in severe conditions.
Still, some people stick to the 3,000-mile changes, because “the Jiffy Lubes of the world have done a good job convincing people,” Mr. Martin said
It’s not just the fast oil change outlets. My sticker from my trusted mechanic states that I’ll need a change in 3,000 miles or three months. But Jiffy Lube, the largest quick oil change company in North America, is now under pressure to change its automatic 3,000-mile recommendation.
For about a year, the company has run a pilot program with some franchises across the country suggesting that instead of a blanket recommendation, mechanics tell customers what the manufacturer recommends under mild or severe driving conditions.
“By this time next year, every Jiffy Lube will do it,” said Rick Altizer, president of Jiffy Lube International. And the little sticker on your windshield will no longer simply state when the next oil change should occur, but, “I choose to change my oil” at a specific mileage.
“It’s so it’s not some arbitrary technician saying this,” Mr. Altizer said, but the consumer’s decision.
Mr. Reed of Edmunds.com said car owners often got conflicting messages because of an inherent tension: “The car manufacturers want the reputation that it makes cars that last a long time. The dealership wants to see you every three months.”
But he acknowledged that “3,000 miles strikes a deep chord with the consumer,” adding: “It feels good to get an oil change. If you fill up the car with gas, wash it and change the oil, it runs better. Of course, it doesn’t. But it’s the perception.”
Although Mr. Reed is doubtful that most drivers fall into the severe driving category and fears mechanics will use that to push drivers into paying for more oil changes than necessary, Mr. Sutherland said he wouldn’t want “to second-guess the manufacturer.” Vehicles, he said, “are a substantial investment and changing fluids is how you protect that investment.”
So before you go in for your oil change, dig out your owner’s manual and see what it says. And when the mechanic slaps on a sticker that gives the next change date in 3,000 miles, ask questions. And then, go get the car washed. That’s one thing that always seems to be needed.
Old Sep 22, 2010 | 07:12 AM
hawkeye18's Avatar
Ah, thank you for posting that. It was worth the read.
Also, perhaps I just wanted to post the other al gore meme for the lulz! (it did want me to sign up, though)
Old Sep 24, 2010 | 06:40 AM
So you think you could REALLY feel grittiness though surgical gloves and would trust this judgement that your oil still has some life left in it ?? I don't care how thin the gloves, there's always the chance you may not feel it.
My point was he says to check for grittiness with your fingers, but then throws the disclaimer in there that you should always wear gloves when working with used engine oil. He may as well have said "send an oil sample to a lab, because if I recommend doing it my way (using my bare fingers) I could be liable if you get cancer".
Doug
Old Sep 24, 2010 | 03:43 PM
hawkeye18's Avatar
Doug
An oil analysis is never, ever, ever a bad idea. $30 for a sample to tell you exactly what is going on in your engine, far far better than looking at/rubbing some oil could ever do. Blackstone is where it's at. I swear by them, especially on my 200,000 mile SHO.
http://www.blackstone-labs.com
Old Sep 24, 2010 | 08:05 PM
Drew2000's Avatar
Since a good oil filter filters at about 15-20 microns, if you can "feel grittiness" in the oil, you have a world of hurt going on in your engine.
Old Sep 24, 2010 | 08:48 PM
SD CALSPCL's Avatar
I just did my first change today, at almost 3000 miles, with Mobil 1, which I have been using since 1978. I have always completed the first oil change at 3000 miles simply to replace the factory oil and filter in case there are any metal shavings, or contaminates. The oil was very, very dark as it drained. I will be curious to see how the Mobil 1 looks, in comparison, when I drain it.
I did not reset the service minder which is at 83% and will do the next change when it tells me to do so. These clocks have been around for a long time, on aircraft engines, and with synthetic oil, lengthening the change intervals should not be a problem. I believe it is BMW and Mercedes that do 15000 mile changes in Europe, but not here because of our mind set. We have been born and raised on 3000 miles changes. It really is time to educate people, and save money at the same time.
Old Sep 24, 2010 | 11:05 PM
hawkeye18's Avatar
Mobil 1 filters filter down to 10 microns. K&N filters filter down to 20 microns and emphasizes flow rate, which is higher than the Mobil 1 filters. Wix filters filter down to ~15 microns and are a good in-between substitute. All three brands are made at the same factories and utilize the same construction.
If you use Fram filters, you ought to be slapped.
That is just my personal opinion, though (except the top part, those are facts to the best of my knowledge). And you know what they say about opinions.
Old Sep 25, 2010 | 08:01 AM
David Young's Avatar
I agree with you on the Fram filters.
This 'don't touch used oil crap' is for the people who change oil for a living and auto mechanics. Your not going to get cancer touching the oil on your dip stick LOL!!!
My Dad bought a new Taurus in the middle of January. I changed his oil last week. In 9 months he has only put 1,061 miles on it. He has an 03 Taurus and a F-150, thats why not many miles on his new Taurus. After only 1,061 miles and 9 months, the oil was very dark and the oil life meter was down to 71%.
