damb ignorance (**** ignorance!)
At the risk of inviting stinking piles of ridicule from all the modders here, I have to ask:
What are direct-acting mechanical buckets? Do they have to do with the camshafts or valves?
I'm sure that I'm supposed to be happy about this, but I have no idea why.
3.7 V6 DAMB are buckets that sit on top of the valve/spring assembly and the cam lobe sits directly on them to open the valves instead of having cam followers like the V8 motors.
Think about a small bucket. Now set it upside down over the valve/lock/retainer and spring. Now set the cam on top of the bucket. Thats your entire valvetrain. No follower (OHC version of a rocker). Its like the valvetrain on a 14,000+ RPM Superbike.
Seems like I provided about the same explanation...
Ford is touting it like it is something new. Overhead cams have run on direct acting buckets from the very first OHC motor ever built.
The OHC motors with cam followers are the ones that are not the norm.
Ford's 4.6 3V was the first I personally saw using finger followers that reach out from the cam lobe to the hydraulic lash adjuster (lifter in a push rod engine) that sits on the valve stem. Its sort of a rocker arm (similar to a push rod engine).
The 5.0 really utilized the extended reach of the finger follower and allowed them to play with cam placement and port placement. No more having to have the cam directly over the valve bank/stems like back in the day.
The original SHO engine uses buckets and shims. The SHO engine came out in 1989, a full 21 years ago. Though to be fair it was incredibly advanced for its time. Much like this mustang engine is now. Might be why I'm getting one.
The advantage to buckets is that the fewer times energy changes direction, the more is kept through it all. This is the same concept that results in a SRA using less drivetrain power than CV axles. So, the camshaft pushes directly on the valve; all of the energy is transmitted to the valve. Also, the less moving metal you have, the less inertia you have to deal with.
The reason Ford used followers for the GT was for physical cam placement, IIRC. They wanted the cams as far outboard on the heads as possible for port placement. This usually results in a lower possible red line, but Ford seems to have done ok at 7k rpm. FWIW that was the redline of the original SHO motor as well (although that was just so the dang alternator wouldn't blow up).
Mario Andretti and Niki Lauda...
![](http://www.allcarcentral.com/Monterey_Historic_2008/Mario_Andretti_Lotus-78_PWW0136_Monterey_His_2008.jpg)
![](https://upload.wikimedia.org/wikipedia/commons/d/d4/LaudaNiki19760731Ferrari312T2.jpg)
If so, why is this better than just having the cam lobe push directly on the valve-stem?
Thanks for everyone's info!
On my Lotus (all aluminum even back in '74) they went out of adjustment between 7-10k miles. The valve wears deeper in the seat over time and the top of the valve stem can wear from the constant action pushing it down - both of which affect clearance between the top of the valve stem and the inside of the cam cup/bucket (we simply called them cam followers back then). If the clearance was too tight the valve wouldn't close all the way. The resulting gases seeping past on the combustion cycle would in time burn/warp the valves, which would prevent complete closure and affect performance (the combustion chamber is leaking). If the clearance was too great, the valve wasn't opening completely (again robbing performance because you weren't flowing at full capacity).
Different thickness shims are used to get the clearance to spec. Cold spec exhaust valve clearance was .010 - .012, the intake valve clearance was .005 - .007. I was always taught that a little rattle (tappet noise) was better than none. Your micrometer and feeler guage were your friend.
The cold spec clearance process was the same with pushrod motors back in the day with solid lifters. Although they didn't use shims, there was a stem adjuster with a lock nut on the rocker arm.
Whereas in the case of hydraulic lifters (push rod) and hydraulic lash adjusters (OHC), the hydraulic action of the oil takes up the slack. No more shims and such.
In the case of the new 3.7 and the DAMB, I assume this is a hydraulic lash adjuster of some sort between the lobe and the top of the valve stem. Hence the "dynamic actuated" (hydraulic) mechanical bucket. Just a hunch. I haven't read up on it.
The bucket spreads the load out across the cam lobe just like a lifter does on a cam lobe in a OHV motor. A cam lobe acting directly on the valve stem would wear a groove in the cam and wear the top of the valve stem down pretty quickly.
