Critters inside the vehicle.
Old Apr 11, 2016 | 12:28 PM
  #81
MadcapMagician's Avatar
Sounds like you need to burn the garage down and then take the mustang out for a ride that's so fast it will make the engine paint smell. Problem solved...no mo critters.
Old Apr 11, 2016 | 04:19 PM
  #82
VidPro's Avatar
Legacy Tms Member
Wish I had a garage.
So the adjuster is coming out tomorrow. Talking to him over the phone, it looks like the firewall insulation is covered too. Now I get to see by how much. I'm sure it will be a smooth process.
Old Apr 12, 2016 | 08:15 AM
  #83
VidPro's Avatar
Legacy Tms Member
So depressing. The adjuster just looked at my car. While we were looking at the found damage we found other exposed wires that became dinner for my dead rodent friends. I think this is going to be a full harness replacement. At least it's covered and I will get new firewall padding. Whohoo!!!!!
So I assume this will require my dash etc to be pulled out? *sigh*
One more question. I took of the strut tower brace off. There's no need to put it back on before I take to the dealer, right?
Old Apr 12, 2016 | 09:04 AM
  #84
Found another use for my mouse traps! Critters inside the vehicle.-photo933.jpg
Old Apr 12, 2016 | 09:50 AM
  #85
Blown CS's Avatar
Found another use for my mouse traps! Attachment 178157
Wolfe spiders?
Old Apr 12, 2016 | 09:54 AM
  #86
Blown CS's Avatar
Yes you can run without the brace and non premium cars doesn't have the brace.
Old Apr 12, 2016 | 11:07 AM
  #87
Originally Posted by Blown CS
Wolfe spiders?
Old Apr 13, 2016 | 07:26 AM
  #88
Coyote5-0's Avatar
That's not entirely true btw. I have a base GT and it came with the STB
And VidPro, I don't see why they would have to remove the dash or any interior components.
Old Apr 13, 2016 | 07:38 AM
  #89
VidPro's Avatar
Legacy Tms Member
That's what I'm hoping. I assumed that if the harness needs replacing they need to dismantle the dash. I hope to get a call soon on the estimate. I told them I want it back to factory and if it's better to replace the harness do it.
Old Apr 13, 2016 | 03:11 PM
  #90
VidPro's Avatar
Legacy Tms Member
I just talked to the shop. So it looks like they will be replacing connectors where the damage occurred. I think that's probably for the best if it's done right and looks factory.
The one thing that has me freaked is that they told me that the tranny might need to be dropped to replace the firewall padding. WTF? That's gotta be wrong, right? She said the tech said that's probably not the case but wanted me to know. Needless to say I am heading over to the shop tomorrow to speak to the tech and get the details of what's going on.
* triple sigh*
Old Apr 14, 2016 | 06:37 AM
  #91
Coyote5-0's Avatar
Don't worry about them dropping the transmission... That's not a very invasive job. And aren't these transmissions electronically controlled so they wouldn't even have to remove anything in the interior around the shifter? Even if not, all they would have to do is remove the shift linkage to the transmission.
Old Apr 14, 2016 | 08:47 AM
  #92
You know what I was thinking... You're doing all this replacement and fixing, which is fine. But, have you addressed the root cause of the problem? Meaning, the "got dam" critters? . If not, you'll have wasted all this time, money, and frustration for nothing. If you're still outdoors, it will happen again. You won't be able to kill all the mice/rats outside. Or are you getting a garage?
Old Apr 14, 2016 | 10:57 AM
  #93
Coyote5-0's Avatar
Speaking of critters.... They are hanging new power lines near my apartment and garage. The entire area underneath them used to be an overgrown field with really tall grasses and bushes. I can only imagine how many "got dam critters" got displaced when they plowed it all down. I need to check that garage now and lay a new perimeter of moth *****.
Old Apr 14, 2016 | 11:24 AM
  #94
VidPro's Avatar
Legacy Tms Member
Thanks for the info.
Old Apr 14, 2016 | 11:26 AM
  #95
VidPro's Avatar
Legacy Tms Member
Addressed for at least for two of them and no return since. I think a month or two now since any activity.
This is the first time I've ever had this problem and I'm hoping the last. I will continually take precautions by setting traps and other goodies for the varmints but that's all I can do for now until we buy a new house in a couple of years. I am going to look for winter storage again and hopefully i can afford it.
Old Apr 16, 2016 | 07:05 AM
  #96
I like the latter suggestion. If house is a couple years away, winter storage indoors is a must.
Old Apr 16, 2016 | 07:32 AM
  #97
VidPro's Avatar
Legacy Tms Member
That will be the plan. All depends on how much. I'll start looking at options.
Old Apr 16, 2016 | 08:39 AM
  #98
Coyote5-0's Avatar
So I was looking at the firewall insulation when I had my hood open...and ****. I feel bad for the tech that has to install that. There's like 2 inches of clearance at most. I'm surprised they don't have to remove the engine
Old Apr 17, 2016 | 06:27 AM
  #99
VidPro's Avatar
Legacy Tms Member
Why did you have to say that!?! LOL!
Old Apr 18, 2016 | 06:28 AM
  #100
Coyote5-0's Avatar
I don't know how they get it on and off considering there is 1-2 inches to work with at most. Open the hood and take a look
