crap something bad happened
Old Nov 25, 2016 | 03:02 PM
Winkawak's Avatar
While topping off my engine oil couple drop of water(sweat) fell in the engine, am i screwed? Car seems okay on my way home but not sure about long term damage.
edit
Im not offended at all, might sounds stupid to yall but to me its a legit question. I rather look dumb asking the question than not knowing. This is my first car so i still got much to learn and ill probably get more of you a holes on the way but hey its all part of the online experience.
Old Nov 25, 2016 | 03:55 PM
ElkGroveFordGuy's Avatar
That should not have any effect on the engine!
Old Nov 25, 2016 | 04:03 PM
Winkawak's Avatar
What amount would cause a concern? I always hear there should be no water mixing with engine oil, should i change my oil to be sure or is it too late since i drove few miles home after it happened?
Old Nov 25, 2016 | 04:07 PM
David Young's Avatar
Moisture gets into the oil all the time. Condensation happens and it gets burned off. You'll be OK.
Old Nov 25, 2016 | 04:11 PM
slow.stang's Avatar
David is correct, it's already evaporated and gone through the pcv and back out the exhaust.
Old Nov 25, 2016 | 04:27 PM
TheReaper's Avatar
You should probably check the air pressure in your tires.
Old Nov 25, 2016 | 04:35 PM
First off don't drive the car
Clearly you are not intelligent enough to operate a motor vehicle
Secondly you should always use birth control
Old Nov 25, 2016 | 04:39 PM
slow.stang's Avatar
****, you guys are brutal.
Old Nov 25, 2016 | 06:18 PM
GrnT's Avatar
I think it could explode. Go to the parts store and ask for some canned steam. That stuf will fix your problem fast.
Old Nov 25, 2016 | 07:20 PM
What happened to the idea of no dumb questions!
You guys are brutal!
Funny but brutal!
Old Nov 25, 2016 | 07:31 PM
Winkawak's Avatar
Old Nov 25, 2016 | 07:43 PM
Sarge's Avatar
If that happened in a comic book, your car would probably get superpowers.
Old Nov 25, 2016 | 08:20 PM
Old Nov 25, 2016 | 08:36 PM
TheReaper's Avatar
I'll poke at you but I won't steer you wrong.
Old Nov 25, 2016 | 08:40 PM
GrnT's Avatar
Originally Posted by 2k7gtcs
Old Nov 26, 2016 | 12:16 AM
Joeywhat's Avatar
Toss a half gallon in there and you'll probably have issues.
Remember that when your engine is cold and warms up, condensation occurs. Once it reaches full operating temperature it's plenty hot enough to evaporate any water mixed in.
Old Nov 26, 2016 | 01:20 AM
Hey you took it in stride. How old are you, if you don't mine me asking? There might be some hope for our generation yet!
Old Nov 26, 2016 | 02:29 AM
Twin Turbo's Avatar
It'll be fine.......don't sweat it
Old Nov 26, 2016 | 08:09 AM
HA HAAAAAAAAAAA
I see what you did there.
Old Nov 26, 2016 | 03:04 PM
Now I get it. (I'm blond)
