Clicking sound from door panel
Got this weird sound coming from the passenger door area. It sounds like something moving back and forth. Once I press on break, and again when gas is applied. Taken off door panel and found nothing loose. Drove it without the panel and same thing. Hard to hear where its coming from. Any thoughts?
It would drive me nuts. I hate anonymous noises such as this.
So far, it was the rear view mirror and a loose bolt on front fender. Still trying to locate the squeak what it seems to be coming from passenger quarter panel inside the cabin. Now that you mentioned, mine could've been the door panel.
The mirror, was replaced under warranty but it started to squeak again a bit recently. I'm thinking my Coilover suspension is being too harsh on body over time daily driven. The bolt did catch me off guard though. I was like, 'wtf dude?' lol.
Did you check the glovebox?
I had a loose window regulator bolt. Did you check those? I had a thread out there quite awhile back with photos. Mine has started up again. Am beginning to wonder if the Lopey Idle on my tune is vibrating stuff loose?!
I do hate noises like that. I've had some luck by having a friend, or the wife drive the car while I was in the back seat doing some yoga moves trying to find one of those errant noises. Good luck.
Are you sure this noise is coming from the passenger side door panel? How many miles do you have on the car? Some members here have had the click clack noise at a certain mileage that turned out to be sway bar & end link bushing failure including myself (usually 20-30,000 miles or so). Noise usually is right rear side.
