Change in gas mileage
Old 11/27/11 | 10:49 PM
2012BLKV6's Avatar
First of all, I have a 2012 3.7 with 4000 miles on it. My gas mileage seems to have changed pretty drastically over the last week. I have gone from averaging 21 (commute has a lot of lights) to around 17. All calculations have been done manually without the avg mpg readout (which we all know is a pessimist)
Anyone know what could be causing this? My driving has been the same I have not noticed any other changes. Could it be the MAF has been dirtied with filter oil? I installed an airaid CAI around 1000 miles ago. Thanks for your help!
Old 11/27/11 | 10:57 PM
Ltngdrvr's Avatar
Winter blend fuel will kill some gas mileage.
Doubt it's filter oil fouling the MAF unless you re-oiled the filter and used too much.
Old 11/27/11 | 11:57 PM
MustangGTPilot's Avatar
In the fall / winter your MPG will go down due to the thicker air, but also with the CAI your pulling more air and thus need a little more fuel to keep the right fuel air mix. However you do seem to have a big difference. Did you also install a tune with the CAI??
Old 11/28/11 | 06:40 AM
2012BLKV6's Avatar
i have not re-oiled the filter and i do not have a tune (yet).
Old 11/28/11 | 08:41 AM
Ronin38's Avatar
Possibly due to the winter fuel blend, also- check your tire pressures!
Old 11/28/11 | 02:07 PM
Siber Express's Avatar
Winter fuel, my 2010 went from 28 to 24, just like last year
Old 11/28/11 | 02:24 PM
2012BLKV6's Avatar
after reading into the winter fuel blends I think you guys are right. I probably never noticed it on my truck because it didn't have an avg. MPG readout (and it got awful mileage in any season)
I don't mind the lowered efficiency if it's normal, just wanted to make sure nothing was wrong. Thanks for the reassurance!
Old 11/28/11 | 03:50 PM
jimmbbo's Avatar
Are you buying the same fuel as before? Has the fuel been changed from dino-gas to "ethanol-enhanced"?
E85 fuel costs about 10 - 15% MPG....
Old 11/28/11 | 04:47 PM
Ltngdrvr's Avatar
Well, it won't run on E85, and you lose more than 15% running it in cars that it will run in.
Old 11/29/11 | 06:34 AM
2012BLKV6's Avatar
no, i am not running E85. haha. that would be problematic.
Old 11/29/11 | 07:09 AM
RadioFr33Europe's Avatar
I hear diesel cars get better mileage. Maybe try the green pumps.
Old 11/29/11 | 07:21 AM
2012BLKV6's Avatar
oh i heard the opposite.... so i put 93 octane in my girlfriends TDI.
Autotooner
11/24/17 01:42 PM
NC14GT
9/10/17 05:47 PM
ricky1728
2/11/16 08:25 PM
mx5jhb
9/30/15 05:44 PM
DerekShiekhi
9/30/15 07:59 AM
