Central point for jacking front?
Whats up guys, i need to do some exhaust work on my 13' gtcs so im purchasig a low profile jack (lowered on pro kit) I already have a few jackstands. I know how to jack one side at a time but can anyone recommend a central jacking point to elevate both sides of the front end at the same time? And maybe a good place to put my stands? Im a little paranoid so i imagine ill use a cinderblock or something as a back up failsafe if my jackstands were to fail. If anyone can point me in the right direction i'd appreciate it! Ive been searching for a few hours and can't find a central point.. If one exists.
The only central point in the front I've heard of anyone using is the center of the K member. But it's tough to get a jack that far under the car, especially if lowered. You would need to drive up on some ramps or 2 x 12's first to gain enough clearance for the jack.
Center of the K and then use the pinch welds on either side with your jack stands.
I had a similar question. I have been using the "knife edge" just behind the side skirt to jack each side at a time. I know there are other acceptable places to put a jack or jack stands on the uni-body, but I don't know where exactly. And I'm a little afraid to try. Is there any pictures or graphics to show acceptable locations?
Originally Posted by 5.M0NSTER
(Post 6769351)
Hnm my jack stands look like they will crush the pinch weld :/ is it ok to jack one side and put a stand, then do the other side?
Thanks for all replies i appreciate it! |
Originally Posted by YouGoGlenCocoa
(Post 6769398)
Hnm my jack stands look like they will crush the pinch weld :/ is it ok to jack one side and put a stand, then do the other side? Thanks for all replies i appreciate it!
Your pinch welds won't crush. They may crinkle a bit but people have been supporting vehicles on pinch welds forever.
(Post 6769384)
The pinch welds/notches in the plastic are the right spot but you'll want either these (http://www.zl1addons.com/index.php/p...ck-pads-detail) or this (http://www.latemodelrestoration.com/...FUcV7Aodn1UAkg) to prevent damaging the pinch welds.
Originally Posted by RubyRedMCA_Beast
(Post 6769409)
While the factory may say it's ok to jack on a 1/16" wide pinch weld, I see no reason not to place the jack under the K-member, and put the jackstands under the subframe. Can't go wrong supporting a car by the subframe. |
