car in shop running lean
Running lean on stock tune. Haven't tuned it yet. Thank god. B1s2 o2 responding real slow. And computer throwing 10% more fuel to try and fix itself. I love working at a dealership. I know the problem then take to Ford to fix and dare them to give me a no problem found response. Hopefully nothing major needs to be done.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Really. So the o2 problem and lean condition are 2 diff problems. Thanks for the comment. Def thought they could be connected. Glad I told the ford guys both problems. Thank you
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
No engine light on though. Never has been. Hopefully it set a soft code or something. We will see what ford says. Thanks for all the info
Wasn't looking for codes. Was told by Gus at steeda last week to have my o2 checked bc it sounded like one was slow to respond. Then when the tech and I watched them Im real time he noticed the fuel trim was +12% in the short term monitor. So Gus was right. Do have a faulty sensor but the lean condition we saw while checking the o2. It's fords baby now. I just made sure I told the advisor everything that we saw in real time.
Plus car just hasn't felt right since thurs of last week. But with no check engine light on I didn't think there was a problem. Just checked today bc I'm tuning my car as soon as the parts get to me. Want to make sure everything is ok before I do though.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
I'm ok with that. What about the o2 sensor? That should get fixed. Which is what I was taking it in for in the first place. Just added the lean condition bc it was something else the tech and I saw. Oh well. Just want the o2 fixed. if the techs watch in real time they will see the problem with it. Thanks again for all ur info and helping me out.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Either way better to have it fixed now before tuning it. Gus was right the sensor is slow to respond/warm up.
Got car back earlier today in same condition. Ford says everything is within specs. But all the fuel trim numbers that I saw this morning (+10-13%) are stored in the short term monitor and haven't gone to long term yet. So no light or code set yet. The land rovers I see everyday will turn on the engine with a +10% or greater fuel trim. So not sure what to do now other than wait and see if the light comes on. Def not tuning the car for a few weeks now. That sucks.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Lol. I know u were right but 20% is way to high to turn on the light. Land rovers turn on the light at 15%. lean is not a good condition. Right? Where could more air be coming in from to have to throw +10% fuel in the motor.
Lean is mean!! I'm not sure I understand fully... if it is adding 10% more fuel to the standard map it is compensating for the extra air and it isn't actually running lean - right? That is how fuel injection should work...so you don't need to re-jet (if it were a carb) due to elevation changes etc... Do you have lamda ~ air/fuel sensors in the exhaust so you know what A/F ratio you are running?
Cars not tuned yet. Everything stock. I work at a dealer and watched the o2's on a scanner and we happened to see the fuel trim. At time it was at +13%. Didn't seem right to me and a master tech. So I took it in hoping they would see the slow to respond o2 sensor in real time. But I had no light on and there was no codes thrown yet. Gonna give it a few more days and see what happens. Will probably keep checking the o2 sensors like I did today and see if they change from today. Sent a msg to Gus and will wait and see what he says.
