Brake question
Old Jun 7, 2011 | 02:40 AM
Dub's Avatar
Dub
Brake question
Is there an aftermarket replacement router that doesn't get all rusty. I have the tis rims from the 2011 dub package,they look great (20") but the rusty router and caliper look like crap and are very noticeable on this type of rim. Would Brembos fit? I really don't want to blow the coin thou... Suggestions??
Old Jun 7, 2011 | 08:29 AM
Ltngdrvr's Avatar
Brembos rust just the same.
Just drive it a lot and that will keep the rust worn off.
Part of the rust is from the pad material left behind by the semi-metallic pads. You could change to a ceramic pad and it wouldn't be as bad but it also won't stop as well.
Old Jun 7, 2011 | 08:31 AM
Five Oh Brian's Avatar
I'm fairly certain you want new brake "rotors" - not routers. That said, your 20" wheels will fit over Brembos (based on the diameter), but you may need spacers depending on backspacing requirements. A cheaper path would be to just get stock sized slotted and/or cross drilled rotors (i.e. Power Slots) that are coated to not rust.
Old Jun 7, 2011 | 08:33 AM
I used Hawk ceramic pads on my '07 GT and it stopped much better than stock (after they had little heat in them).
Old Jun 7, 2011 | 08:35 AM
Ltngdrvr's Avatar
That coating is only for the non-friction surface of the rotor. I believe he is talking about the friction surface rusting and showing through the wheels.
Old Jun 7, 2011 | 07:42 PM
Dub's Avatar
Dub
Yep that sounds allot better... Stock sized power slots and caliper covers... Then again after the price of all that It might be worth it to just step up to the brembos...hmm
That's for the info guys
joemad59
Dec 30, 2015 06:13 PM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
1001yos
Sep 8, 2015 10:05 PM
Sep 8, 2015 10:45 AM
