Brake Pads for Base model 2011 GT
Old Aug 13, 2015 | 12:11 PM
SVS's Avatar
SVS
I need brakes pads and wanted to know is there a performance pad available thru Ford?
Ford has a performance parts/racing line of OE parts ... Do they have anything for the Non-Brembo OE set up?
Old Aug 13, 2015 | 08:13 PM
TheReaper's Avatar
They are not Ford but Hawk HPS worked well on my 2011 non-Brembo GT.
Old Aug 14, 2015 | 03:23 AM
x 2 on the hawk pads
Old Aug 14, 2015 | 06:49 AM
5.M0NSTER's Avatar
Another option is Carbotech. If you don't track the car I'd recommend AX6 pads. More bite and slightly more temp resistance.
Old Aug 14, 2015 | 09:21 AM
dmichaels's Avatar
Carbotech would be my choice for DD. Hawks bite hard, but dust a lot and wear pretty quickly from what I've witnessed.
5.Monster's recommendation has my concurrence.
Old Aug 14, 2015 | 11:57 AM
SVS's Avatar
SVS
I'm going to stay with Ford Parts that's why I was wondering if FORD has a performance pad offered. I'm going to keep the Mustang and going to take advantage of their free pad replacement. Want to get the best FORD parts I can.
Took the beast to the Mountains a few weeks ago and went out on Dirt Fire roads...
Rally 5.0!
Old Aug 14, 2015 | 12:03 PM
dmichaels's Avatar
Free pad replacement?
Old Aug 14, 2015 | 01:49 PM
Rog13GTCS's Avatar
What vendor sells the Carbotech pads?
Old Aug 14, 2015 | 04:00 PM
SVS's Avatar
SVS
For the life of the Vehicle as long as you own it. Will need to pay for other costs and Rotors as needed.
This Car works so well as a Stock vehicle I don't have to 'highly modify' it to make it substantially better. Later might do suspension, and a supercharger.
Might do Big Brakes (BAER) along with larger diameter wheels. At that point no Free Pad replacement. Till then I'll stay OE and take advantage of what FORD is offering.
Old Aug 14, 2015 | 05:34 PM
5.M0NSTER's Avatar
You can get pads from Carbotech directly:
http://www.ctbrakes.com/pads.asp?Make=Ford
Vorschlag motorsports also sells them:
http://www.vorshlag.com/index.php?cPath=141_142_280
And there are a few more vendors I can't think of right now too.
Old Aug 15, 2015 | 03:25 PM
kylerohde's Avatar
I put Hawk HPS on my car a month ago and the brake squeak is awful. Don't think I did anything wrong in the install as I know what I'm doing there and it's been to the shop for a full check up since. Any ideas guys? Could my Stoptech rotors be part of it?
Old Aug 15, 2015 | 07:36 PM
dmichaels's Avatar
Huh, I should have found that deal... I get about 400-500 miles out of a set of front pads and 800 out of rears They'd love me
Old Aug 17, 2015 | 10:53 AM
TheReaper's Avatar
Did you bed them properly ?
Old Aug 22, 2015 | 09:51 AM
kylerohde's Avatar
I thought so but am going to try and redo it this weekend. Called Hawk and they suggested replacing the retaining clips even though they don't include them in their pad boxes. They also said to scuff the pads and rotors with 80-100 grit sandpaper and regrease all the usual spots. If I'm going to go through all that, I may just go back to normal premium street pads.
Old Aug 22, 2015 | 05:32 PM
Rog13GTCS's Avatar
I am going to pick up some Ax6, how is the dust and noise.
Old Oct 12, 2015 | 11:19 AM
Chad@Amp'D's Avatar
Former Vendor
I am a new supporting vendor specializing in Carbotech brake pads. If your car is just for street use I would look at the 1521 vs the AX6. The AX6 tends to be noisy on the street and dusty. If you have not bought pads yet and would like to discuss options I will be happy to help you we offer 5% discount for forum members. Feel free to contact me direct at 216-780-8824 or by email chad@ampdautosport.com
Old Oct 12, 2015 | 01:21 PM
5.M0NSTER's Avatar
I have XP8s in the rear permanently, and they do squeak a little, but it doesn't bug me. The XP10s on the front were unbearably loud, so I swapped them in and out for track days. I'd expect the AX6 to be quieter though.
Did you pull the trigger on these pads? How is the noise.
Chad, My XP10 front pads are done now (<3mm lining), and I think I'll replace them with XP12s next seasons for a bit more bite and more fade resistance peace of mind. (I haven't faded the XP10, but I think I came close temperature wise)
Any bias concerns with running XP12/XP8 front/rear setup?
Old Oct 12, 2015 | 01:45 PM
Chad@Amp'D's Avatar
Former Vendor
5.MONSTER, I don't really see an issue running Xp12/Xp8 combo.It would be great if you can tell me what tires you are using for the track? Xp12 might over brake the tire and tend to wear faster then the xp10.
FYI the AX6 is duster and noisier then Xp8
Old Oct 12, 2015 | 06:49 PM
5.M0NSTER's Avatar
Hey Chad,
The Xp12/8 combo will be used with Bridgestone Ponenza S04s in 275 square setup for 1 season, then with BFG Rivals or Potenza RE-11s in 285 square for the rest of their pad life. Do you think the XP12 would over-brake them and I should stick with the XP10 compound?
Also, did you say the AX6 is dustier and noisier than the XP8?
Old Oct 13, 2015 | 08:57 AM
Chad@Amp'D's Avatar
Former Vendor
Hey Chad,
For right now I would stick with the Xp10 and yes AX6 is dustier then the Xp8 because of the carbon content in the AX6. When you are ready please let me know and I will set you up with the pads.
mustangsally_
Sep 18, 2015 05:35 AM
5.M0NSTER
Sep 16, 2015 08:00 AM
1001yos
Sep 8, 2015 10:05 PM
Sep 8, 2015 10:45 AM
