On board diagnostics won't reset
My 2014 GT's battery died in my garage this winter, I think the battery tender must have failed when we had a blackout. I'm in NE Ohio and this is the first year I'm required to get an emissions test. Well, because the battery died, they could not get any readings from my OBD, and I had to pay to get temp tags because my registration expired.
I've been driving it on and off for 2 days straight now, put about 100 miles on it (it only had 2900 when I started) and it still won't reset. I followed instructions that I found online about the drive cycle(start, idle, local driving, highway driving etc...)and I am getting frustrated.
Any ideas or advice?
If you haven't already I suggest you buy a new battery. If you would rather not, try a system reset. Unhook the positive battery cable for approx. 15 minutes, then plug her back up. That may just do the trick. Good luck.
