axle ratio and the 2011
Old Jan 19, 2010 | 05:15 PM
stangfoeva's Avatar
MOTM Committee Member
Gears are - by definition - a torque multiplier. So, yes, you will definitely feel quicker acceleration just in everyday driving. Steeper gearing is one of the more gratifying mods for our Mustangs and is, therefor, one of the most commonly done mods.
Back to that torque multiplication. Let's say you take an '11 GT that has 390 lb ft or torque and has 3.31 gears. Adding 4.10 gears yields about 25% more gearing, which would give the same seat of the pants feeling as keeping the stock 3.31 gears, but adding 25% more torque (up to 485 lb ft torque). Can you imagine how awesome the car would feel with 485 lb ft torque? That's what a stock '11 GT with 4.10 gears would feel like.
You'll find less need to downshift, as each gear will pull much harder than stock. You'll lose just a little bit of fuel economy (maybe 1-2 mpg at the very most on the highway). The 3.73 gears from the factory will be a nice upgrade for your intended driving. Go for it and do not fear the gear!
Jason, I drove a leftover 09 and a 10 with the 3.73s back to back. The 09 had the 3.31s. Granted, the 15 extra hp may have made a difference, but the car picked up so much more in 1st-3rd gear. It was also easier for me to take off in 1st (I have pretty limited experience driving a manual on the street) because the engine revs were higher in the 10. I think if I get my 11 I'm *definitely* going with the 3.73s.
Thanks for the advice guys! I'm definitely getting them now
Hey Patrick you hear anymore about those Recaros yet?
Old Jan 19, 2010 | 06:01 PM
Have not. . Guessing it should be in the order guide as a "late availability option" if they're even available on the GT. I would bet (as Overboost suggested) that they will be a GT500 option only. Probably a part of the SVT Performance Pack.
I'm going to wait a little bit more...I'm really looking at 10s in my area again because I'm not sure I can justify the pretty much $10k increase over the '10 (with rebates and discounts now) just to get the color combo I want. I don't care about the extra power. 315 is definitely enough for me. I just want SG and Saddle interior. I've found a few '10 GTs with Elec/Glass Roof/Comf/3.73s but they're all black on black. I've had dark charcoal interiors for so long now and I want something different. And I don't really want a black car. BUT I could vinyl wrap the **** thing whatever color I want and have the whole interior redone with some Katzkin covers for like $3500. We'll see......hopefully Ford pulled the pricing guide and is adjusting it due to the outcry from our wallets!
Old Jan 19, 2010 | 06:04 PM
stangfoeva's Avatar
I hope they do lower it abit. I know they read these forums too,
Hi Ford
Old Jan 19, 2010 | 06:05 PM
200mphcobra's Avatar
I've always set up my gears based on the 1/4 mile dragstrip. I want to cross the finish line in the 1:1 ratio gear. In the new 6-speed manual, that's 5th gear. Assuming that I would mod the car to run about 12 flat at around 115 mph in the 1/4 mile, I'd need 4.88 gears to turn 7K rpm's @ 115 mph. Or, if I planned on crossing through the traps as noted in the quote above, then 3.73 gears might be a little too steep as they'd be about 114 mph @ 7K rpm's. 3.55's would yield 120 mph @ 7K rpm's in 4th.
The 2nd consideration I use for choosing gears is rpm's on the highway. I can't tolerate anything over 3K rpm's at 70 mph. With a .65 overdrive in 6th gear, even 4.88 gears would only be turning 2,800 rpm's at 70 mph. My '07 GT automatic turns the same 2,800 rpm's at 70 mph, but with 4.10 gears, so the '11 GT will allow for more gear while keeping cruising rpm's constant.
So, for my intended use, I would likely pick 4.88 gears (maybe 4.56's?) and make that car scream through 5th gear at the dragstrip.
It will be interesting to see how all this unfolds with the new gearbox. I have some experience with T-56's, and they aren't easy to speedshift into 5th. This box may be a whole diffrent story though. Some have mentioned seeing less horsepower using the 3.73 due to frictional losses in the gearset(would like to see some hard data on this), but we all know it would not cancel the gain from torque multiplication. I would probably gear it for about 7200 rpm in 4th, at the mph for my modifications, but thats just me, sometimes I like to hold it down on some open road till the speedo stops!
Old Jan 19, 2010 | 09:49 PM
Five Oh Brian's Avatar
Worth noting, the '11 GT is rated at 412 hp with premium fuel (less hp with regular fuel), whereas the '10 GT is rated at 315 hp with regular fuel (premium fuel yields about 10 more hp bringing the '10 GT total to about 325 hp). So, if Ford is going to advertise the premium fuel 412 hp for the '11 GT, I think we should use the same approach with the '10 GT and call it a 325 hp car.
And, yes, 315/325 hp is plenty of power for the vast majority of enthusiasts out there. Thank you for knowing. As your driving skill increases, add more power. Too much too soon is not wise, me thinks. My first car made a whoppin' 105 hp as delivered from the factory. I've worked my way up over the years through small & big block V8's. Several over 400 hp and one that was around 550 flywheel hp. If one of those would have been mine at a young age, I'd likely have died years ago in a fiery crash.
Old Jan 19, 2010 | 09:51 PM
Originally Posted by 200mphcobra
Some have mentioned seeing less horsepower using the 3.73 due to frictional losses in the gearset...
I'll trade a few hp on a dyno for lower ET's at the dragstrip and increased driving feel/enjoyment.
Old Jan 19, 2010 | 11:14 PM
Agreed Brian. My first car was a 95 Contour GL with 150k miles. Had about 120hp. Drove the crap out of it. Next and current car is my 00 v6. Drive the crap out of it. I know my limitations. I know the car. I know that I would be more careful with 400+ hp. We'll see what I end up doing. Gotta save more for a bigger down payment either way.
Rando
Aug 25, 2021 11:12 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
Sep 24, 2015 08:15 PM
