Anyone in the LA area have a set of 18" FR-500s w/ SN-95 offset?
Old Sep 13, 2009 | 01:43 PM
vaheek's Avatar
Hey guys, I just got a 2010 GT and I want to pick up a set of FR500s w/ the 99-04 offset. I wanted to see if anyone has done this already, and if not, if someone around Los Angeles wouldnt mind meeting up and letting me try them on my car to see if the 24mm offset will fit fine on the 2010 before I pull the trigger on a set. Let me know
Old Sep 13, 2009 | 03:47 PM
TTS197's Avatar
Any reason why you would want them in a 24mm offset?
But if you are wondering, they will work.
The issue would be with the tire selection, With a 255 it will be right on at the fender anything larger like a 275 and the tires will bulge out.
Here’s a shot the 18x9 with a 275.
And for reference here’s a shot of my car with some plasma’s 18x10 295’s 28mm offset. They stuck out about an inch pass the fender.
Old Sep 13, 2009 | 09:47 PM
vaheek's Avatar
That picture is exactly why I would want them in 24mm. I've seen the s197 offset fr500s but I prefer the sn-95 offset because it fits very nicely with the wells. If it works on the 05-09, would it look/fit the same on the 2010's? I believe his size is 245/45 all around, but it might be 275 as you stated
Old Mar 6, 2012 | 09:38 PM
dlc1's Avatar
ok so help me i just found a set of smoothie II boyd wheels someone had made and never used ,,they are *****in the size is 18x9 with plus 28 mm offset
will they fit my 2012 gt ,,,any help is appreciated
Old Mar 8, 2012 | 10:10 AM
TTS197's Avatar
I would be careful when buying smoothie wheels, specially is they are used.
Most that I've seen have a GM bolt pattern and wont fit since our bolt pattern is 5x114.3 and as for the offset goes they should work fine depending on tire size.
DarrenGT
Apr 2, 2020 11:52 AM
NC14GT
Sep 10, 2017 04:47 PM
14BlackGT
18
Mar 10, 2017 04:13 PM
