Anyone just replace the shift bracket on the MT-82?
Hope this helps!
Nothing special. I did it myself in my garage. Before you do anything make sure the car is cooled off because you are going to be working near the exhaust pipes. I first backed the car up onto 2 Rhino Ramps. Used my floor jack to lift the right front and supported it by a jack stand, did the same on the left. That was the hardest part. The whole bracket install took all of 10 minutes. To remove the stock bracket you'll have to use a 10mm deep wall socket with a socket extension on the socket wrench. Once the bolts are off the bracket is still held on by a small clip which with a little force pulls right down. You'll have to find what works the best for you under there with the drive shaft in the way. I put one hand through the h-pipe and one in front. You have to wiggle the stock bracket off of the base. Once off, slide the Steeda bushing over the base, the red one went on real easy. Then slide the Steeda mount over the bushing with the Steeda logo facing the rear of the car. It helps to pull the base a little to the side to slide it up with the drive shaft there. Make sure it fits snug before you bolt it back up. Then bolt it back up with the same nuts, just don't over tighten them. Thats all it takes. Also it helps to not be clostrophobic..
Hope this helps!
Hope this helps!
They said they had to drop the driveshaft to get to this and install it?
Seems fishy to me and obviously cost more to do since it took them longer.
Anyone else had to do this?
Originally Posted by Timeless
Thanks for the reply...I let the dealership do this at my last service since I figured with a lift it would be much easier for them.
Like John already mentionned, there is no need to drop the driveshaft.
The first JHR bracket took me roughly about 15 minutes to install, shortly after, i swapped it for the Steeda one with red bushing which took me even less time.
There is room to maneuver around the driveshaft, especially if it's on a lift. I did mine with race ramps. How much time did they put on the work order to install the bracket !
2/10/17 07:12 PM
9/16/15 06:44 PM
