Any eurotek wheel owners please help.
Old Jan 24, 2012 | 07:03 AM
alcarames's Avatar
I had the tires mounted on a new set of eurotek 19' wheels and when the shop went to put them on there were fitment issues with the hubcentric rings as they were too tight and deforming and couldn't get the wheels to sit flat against the hub of the car. Now when I drive on the highway I get a nasty vibration and wobble. The wheels were properly balanced so it's definitely the cause of the plastic rings not fitting properly causing the wheel not to sit flush. Any help on what you owners did to remedy this issue?
Old Jan 24, 2012 | 12:18 PM
CaptDistraction's Avatar
are you sure the ring sizes are correct? They should be a tight, but not impossible fit as you describe.
Old Jan 24, 2012 | 12:24 PM
alcarames's Avatar
I didn't mount them but the tech working on my car showed me and it was tight. Capt, I know you have the same wheels did you have to use any grease or anything to get them on? I did double check with bob from eurowheels and they are the right hub rings.
MRGTX
Jul 21, 2015 02:08 PM
aphaynes
Rocket City Mustang Club
Jul 9, 2015 09:25 AM
