3M Spray Clear Bra Review
Old Apr 8, 2014 | 07:36 AM
Dfink114's Avatar
Let me first start off by saying I originally didn't want to do the spray on since I haven't heard many positive things about it. Over the winter I bought a roll of Xpel clear bra to protect my chin spoiler. Since it's painted, I've seen and heard from people saying that it gets chopped to hell with rocks when you drive it. I probably drove my car 3-4 times without any protection on the chin spoiler and I already have 2-3 small chips.
So when the weather reached the recommended temperature for the install, I tried to install the Xpel myself. I bought a roll of the stuff, not a custom fit piece. Long story short, I did a crappy job and wasted $40. I removed and hard to throw it away. I was not a happy camper.
I then went to my plan B, 3M Spray Clear Bra. I figured for something like the chin spoiler, this might be a good solution for protection. The can comes with a tube of wax, spray can, and instructions.
I masked off the entire front of my car except for the chin spoiler. I thoroughly washed the spoiler and applied the wax that it came with. 3M recommends waxing for easy removal, if needed. (The life of the clear bra is at least a year).
You then spray the crap on your car at a steady pace, without stopping the spray between coats (which they recommend at 3). You wait a couple of hours and park it in the sun to fully cure.
Here is right when I finished spraying and took the painters tape off. It's still wet, so naturally it doesn't match the car
Here's a close up of the clean line I was able to achieve with pulling off the tape while it was still wet
Another angle
This was the following day. The spray dried and became totally clear.
Different lighting
Up close
Even closer. I may have sprayed a little too heavy in this one area, causing it to run a little. I was concerned that I would have to respray the spoiler, but it only takes 20 min to do, so it wouldn't be the end of the world
Here it is totally dry. I was impressed how clear the bra looks out of a can
I pulled it out of the garage to test it in the sun. Looks good to me!
You can see the run in the chin spoiler clearly in this picture. Although it looks obvious, it was very hard to take a picture of it. Once it fully dried, most of the time I couldn't find it even though I knew where it was. I still have plenty of spray left in the can, so I could spray it one or two more times if I need to.
Here she is at the first show of the season on Sunday. Can't even tell it has a clear bra.
I recommend this product for doing something small like this. I'm not sure on bigger projects like the hood, but it seems perfect for something like this. I'll give an update later on to see how it holds up and how it protects.
Here's the video on removing the clear bra:
File Type: jpg
Old Apr 8, 2014 | 09:53 AM
Deep Blue's Avatar
Cool write up. I was wondering about this stuff. Did they recommend to take the tape off before it was dry? Looks fantastic!
Old Apr 8, 2014 | 10:22 AM
14Glassback's Avatar
So does it just peel off if it gets damaged or you are unhappy with the install?
Old Apr 8, 2014 | 10:51 AM
looks stock to me.... nice werk
Old Apr 8, 2014 | 10:55 AM
Dfink114's Avatar
Yes. That way you get a clean line. Otherwise the bra will dry to the tape and when you remove it, you'll take the bra with it.
Yup. Exactly.
Old Apr 8, 2014 | 11:09 AM
GrnT's Avatar
Old Apr 8, 2014 | 11:40 AM
Fink nice job! I was always wondering about this, and now I know. I have a spot on my Acura I want to try, and also the headlights on my mustang I'd like to get covered.
Where do you recommend buying the stuff?
Old Apr 8, 2014 | 01:08 PM
Dfink114's Avatar
I bought it from amazon. I think it was $25
Old Apr 8, 2014 | 01:40 PM
wanted33's Avatar
Thanks for the write-up fink. I was thinking of this stuff for my F-150 when I take it across the country in August. Looks like I'm good to go now.
BTW, I saw it a Wally World this weekend for 22 bucks if anyone is interested.
Old Apr 8, 2014 | 03:40 PM
Originally Posted by wanted33
Thanks for the write-up fink. I was thinking of this stuff for my F-150 when I take it across the country in August. Looks like I'm good to go now. BTW, I saw it a Wally World this weekend for 22 bucks if anyone is interested.
I assume in the paint department?
Old Apr 8, 2014 | 05:58 PM
Originally Posted by Dfink114
Yes. That way you get a clean line. Otherwise the bra will dry to the tape and when you remove it, you'll take the bra with it. Yup. Exactly.
Awesome job! I swear someone else used this on here and it did not come out that good...
Old Apr 9, 2014 | 01:18 PM
wanted33's Avatar
This store had it in with the waxes in the auto section. But you know how Wally World is, another store could have it in the grocery section.
Old Apr 10, 2014 | 08:41 AM
Horspla's Avatar
...well it does look a like a pretty tasty prodcut
OP, thanks for posting this. You did a good job applying it minus a few minor glitches that could happen to anybody! I'm looking forward to hearing how well it works and holds up. Could be the answer to my quest for paint protection.
John
Old Apr 10, 2014 | 08:55 AM
Dfink114's Avatar
This weekend, I'll be spraying a small patch on my DD and see how easily it can removed. I'll update the post with the results.
Old Apr 10, 2014 | 10:54 AM
CiniZter's Avatar
thanks for the write up.. cool product
Old Apr 12, 2014 | 06:21 PM
whowasthat's Avatar
nice stuff,
why not spray the whole front end? i would be tempted to do the hood too
Old Apr 12, 2014 | 06:59 PM
thegreenmachine's Avatar
Looking forward to hearing how this goes ...
Old Apr 12, 2014 | 07:29 PM
Michael Broadway's Avatar
Very nice job!
I notice in the photos that you don't have a front license plate. Are they not required in your state, or have you just been lucky so far?
Old Apr 13, 2014 | 08:34 AM
Dfink114's Avatar
Originally Posted by Michael Broadway
Very nice job!
I'm in Jersey and it's required. I guess I've just been lucky....for now.....I do have the fold away plate, but it doesn't clear the chin spoiler. I'm sure if I lower the bracket it could work, I just haven't done it yet.
Old Apr 13, 2014 | 12:31 PM
Dfink114's Avatar
