3.73 Gears?
Old Jan 24, 2014 | 09:35 AM
iceD's Avatar
3.73 Gears?
Okay guys so i might be getting this mod soon. Wanted some opinions and insight about it. I have a 2014 v6. I found these 2 links:
http://www.ebay.com/itm/Ford-Racing-...1b30f3&vxp=mtr
What is the difference between the 2 links? Do i need the extra set of rings and bolts etc?
Also will i need a tune after i install the gears?
Old Jan 24, 2014 | 10:08 AM
Ajcruz1's Avatar
It doesn't seem as tho either one of those comes with install kit. If you look at the gears with install kit on A.M. you will see what I'm talking about and you will need a tuner or the speedo recalibration tool to correct the speedo.
Old Jan 24, 2014 | 10:14 AM
iceD's Avatar
http://www.americanmuscle.com/ford-373-2011v6.html
Old Jan 24, 2014 | 10:34 AM
Ajcruz1's Avatar
No this:
http://www.americanmuscle.com/373-ge...-kit-1014.html
and this if you don't want to get a tuner but I would just get a tuner unless you never plan on tuning your stang.
http://www.americanmuscle.com/hypert...al-1114v6.html
Old Jan 24, 2014 | 10:58 AM
JCStang's Avatar
or just pay your dealer to update it....when I thought about doing this, I think they quoted $50 or $60 to do it...
Old Jan 24, 2014 | 11:12 AM
Ajcruz1's Avatar
He has a v6 and as far as I knew the dealer can't flash for 3.55 or 3.73 on our v6 b/c it's not a factory option. My dealer told me they couldn't do it a few months ago.
Old Jan 24, 2014 | 11:34 AM
JCStang's Avatar
Odd....the car I was going to add the 3.73's to was my current V6 and my dealer said they could do it....
Old Jan 24, 2014 | 11:43 AM
Ajcruz1's Avatar
Like I said that was as far as I knew. Im not sure about it. It might be dealer dependent, as in some will do it and some won't.
Old Jan 24, 2014 | 12:33 PM
iceD's Avatar
ill ask them thankyou guys.
@Ajcruz1 I do plan on tuning it in a few months. maybe even sooner.
Old Jan 24, 2014 | 04:10 PM
David Young's Avatar
I don't know why but, i've changed my rearend lube 5 times. Two times with the factory 3.31 gears and three times with my 3.73 gears. Each time the rearend held 2 and 1/3rd quarts with the 4oz bottle of friction modifier. Why they always sell only two quarts i'll never know. Other web sites rearend kits also come with only two quarts of lube.
I have the factory gear cover so 'maybe' with the fill and drain gear cover the rearend fills with two quarts but with the factory rear gear cover it takes 2 1/3rd quarts to fill. Just saying.................
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
