2018 oem and 20” Hyper wheels on a 2013
Old 2/4/23 | 05:30 AM
ramairgt1's Avatar
Does anyone know if the oem 20” hyper silver wheels fit on a 2013 GT with brembos?
I tried to search with no luck
Old 2/4/23 | 11:02 AM
05stangkc's Avatar
The Analog Admin!
I doubt they will Fit in the Front without about a Spacer. I have a Similar Set I have been Planning on Using on my 07 Gt-500 Which has Brembo's. After Test Fitting I had a Set of Custom Spacers Made & Have Special Lug Nuts which Regain the Lost Threads. Never Got Em Put on as of Yet Though! I know they will Clear Caliper Now, But No Actual Test of if Tire May Rub Fender!
KC
Old 2/4/23 | 05:02 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
KC
Is that all because of offset difference in the s550 vs 197 Kevin? I would think they would clear the brembos on 197 around the top of the caliper, but is the offset too shallow not let the spokes clear the face of the caliper ?
Old 2/4/23 | 05:54 PM
ramairgt1's Avatar
Thanks for the reply.
I saw a guy was selling a 14 GT with those wheels and he told me he needed 1” hub centric spacers to clear the brembos
Old 2/4/23 | 07:10 PM
05stangkc's Avatar
The Analog Admin!
On My Car it Needs a Minimum of About 3/8 Inch to Clear Face of Caliper! My Wheels are off a 2015 Gt I think it's Been awhile and Are New Take offs 20x9 Inch. I Have Some 2015 18x8's as Well. They Clear Better But My 500 Needs Biggest Tire I can get Out Back So if I ever get them on it will be the 20's May put the 18's on My P-71. New Sets But aging Quickly!
Need to Do Write Up or Just Post Some Pics on My Special Lug Nuts which Let you Run Spacer Without Changing Studs or Using Wheel Adapter Type Spacers! It's Been a Long Day! See What I can Do Later!
KC
Old 2/4/23 | 07:11 PM
05stangkc's Avatar
The Analog Admin!
You are Welcome!
KC
Old 2/4/23 | 11:38 PM
Like Father...
I ♥ Sausage
KC
Get you a set like my new one, I'm sure 335s will fit on it, came with 315 but might not clear your rear shocks.
Old 2/5/23 | 04:45 AM
05stangkc's Avatar
The Analog Admin!
The Take Offs Were Free to Me So That was the Big Draw!
KC
Old 2/5/23 | 09:52 AM
Siber Express's Avatar
The guy I know at the cruise in that was trying to run those had 5/16th or 3/8th of a spacer to clear his Brembos and ended up selling them to another guy up there that had them on his Black V6.
I found it just easier to buy wheels that I know fit Brembo Brakes.
BTW Kevin, my little V6 has 295's on the rear, not for going straight either. The straight aways on the Dragon are not that long.
Brembo wheels looked really good on a Panther
Old 2/5/23 | 12:05 PM
05stangkc's Avatar
The Analog Admin!
They Were Free with New Tires So Hard Not to Try & Use on Something! I got a Strong Use What you Got Gene in my Bod! If I had My Dream Wheel they would Be the Front BBS Wheels off a 05-06 Ford Gt Supercar. Brad Barnett had a Similar Looking Wheel if not Actual Ones I can't Remember for Sure on the Source Horse! They are Like A Better Looking Version of the Stock GT-500 Wheel To Me. If That Makes Sense.
Just Remembered I did this Post awhile Back! I think The Company That Made These Though are No More!
https://themustangsource.com/forums/...9/#post6992999
KC
Gstep1960
10/17/21 09:28 AM
