2014 GT TP: Ye Old Rear Creak
I've read every thread of this sort across the internet over the last four days, yet I feel compelled to add my own clutter to the ol' interwebs. Here's the run down:
Location of noise: Passenger rear What's on the rear of the car? Whiteline panhard bar and brace/LCAs/UCA (revised)/and LCA relo brackets, Steeda Sports + Koni Str.ts. Parts have been on the car for about a year with no noise until 2 months ago. Provoked by: Suspension movement in general, but especially over speed bumps, ramps, and other irregularities. What others have said: rear deck lid/seal noise; top strut mount over/under tightened; Swaybar/end link bushings; muffler hangar; unruly trunk monkey What I observed: Noise present with rear deck lid fully opened; noise not apparent when bouncing the rear end; no noise apparent when trying to move the sway bar or the end link. I'm not sure what's going on here and I'm sure that my manly arms aren't enough to recreate the actual forces exerted on the suspension while traveling, but is there anything else I should be checking? Kinda bummed! Of all the cars I've owned over my lifetime, this is the first that's been this noisy - and let's get crazy and disclose that among those are a 1984 Nissan Pulsar, 87 T-bird Turbo Coupe, several MR2s, a S2000, and many others! This is my first new car. Bummerelli. |
I had a creek in my car and it ended up being that the steeda lcas I had were not sufficiently lubed on the inside of the bushing were the bushings contact the inside of the lca. I believe you have white line lcas that don't require grease. I don't know if that is the issue but good luck. I went nuts for a month looking for the noise.
Originally Posted by Mr. V
(Post 6709277)
Try hitting things on the rear suspension and see if anything makes the same noise. Sounds low tech but that is how I found the end links to be making noise. Heavily greased them and it went away.
Originally Posted by Brandon302
(Post 6709416)
