2013 V6 Grill - Remove/Replace Chrome Overlay?
Old Jul 26, 2012 | 12:26 PM
Zathu's Avatar
Has anyone looked at or attempted to remove the chrome overlay in the 2013 V6 & Canadian GT grill?
It looks like it may just be snapped in, but I'm not sure if it's "pretty" underneath or if I'd need to get a new grill altogether to remove it.
Old Jul 26, 2012 | 02:46 PM
GreenCars's Avatar
Nope, have not heard anyone doing it. It is more subtle on some colors than others. I personally like it.
Old Jul 27, 2012 | 01:52 AM
watchdevil's Avatar
It's chrome plated plastic. Sand it down and spray it black. I happen to like the chrome plating and I would never touch it!
Old Jul 27, 2012 | 06:18 AM
cinque35's Avatar
use plastic-dip
Old Jul 27, 2012 | 08:22 AM
youngstang90's Avatar
Originally Posted by cinque35
use plastic-dip
+1
That'll give you the option down the road to have it back if you want.
Old Jul 27, 2012 | 10:08 AM
jmillz's Avatar
Yea I was considering taking it out, sanding it, and spray painting it. Does anyone know if you would need to take off the whole front bumper?
Old Jul 27, 2012 | 01:15 PM
GreenCars's Avatar
i would do the plastic-dip as was suggested. Then if you go to sell the car etc.. you can peel it off..
Old Jul 27, 2012 | 01:17 PM
jmillz's Avatar
yea. youre probably right. I just don't want to have to take off the whole bumper, because I dont want to have to jack my car to get under it.
Old Jul 27, 2012 | 02:18 PM
Why would you have to take off your bumper to plasti dip it??
You just cover and spray. Easy as pie!
Old Jul 27, 2012 | 02:19 PM
jmillz's Avatar
I want to replace the stock grille with the UTV billet one, that's what I was wondering about taking the bumper off. I plan on doing the plastidip on the chrome piece at the same time.
Old Jul 28, 2012 | 12:38 AM
watchdevil's Avatar
You should not have to take the bumper off. Lift the hood and remove the plastic black cover between the grille and radiator. Everything should be exposed so you can work out the snap-in tabs on the back of the grille.
Old Jul 29, 2012 | 09:42 PM
jmillz's Avatar
You should not have to take the bumper off. Lift the hood and remove the plastic black cover between the grille and radiator. Everything should be exposed so you can work the snap in tabs on the back of the grille.
hmm, interesting. I'll have to take a look
Old Aug 2, 2012 | 08:48 PM
Zathu's Avatar
I think I'm going to try this. I'll post pics afterwards.
Thanks!
Old Aug 2, 2012 | 11:52 PM
jmillz's Avatar
I just plasti dipped my grille surround, pony, and rear faux gas cap:
Old Aug 3, 2012 | 12:08 AM
CannonBaller's Avatar
I'm getting a Canadian spec GT.
Can't stand the chrome grill.
I ordered a Boss grill and will be putting that in, as soon as I get my car home.
Basically the grill comes in 2 peices. (the Boss anyway).
I will assume the V6 (ummmmm....GT grill), does also.
There is an outer peice (which in this case would be the chrome surround),
and the actual grill part, which would be the innner insert.
The Boss grill actually came in separate peices, I had to snap them all together to form the whole grill.
As for as replacment. Like mentioned in the previous post.
Just remove the black rad shrould from the top, and teh Gril just snaps in place. It's probabbly held on by 2 bolts (one per side).
I'll be changing mine, this weekend most likely.
Old Aug 3, 2012 | 07:45 AM
cinque35's Avatar
pic's when you're done!
Old Aug 3, 2012 | 04:12 PM
Zathu's Avatar
Well I just finished the plastidip. It turned out to be a little tougher than expected to "trim it down" because of all the curves. I may redo it at some point with the grill removed. Does anyone have any reference material for removing the grill? Is it easy?
Here's the in progress and final product:
2013 V6 Grill - Remove/Replace Chrome Overlay?-image-3281252841.jpg
2013 V6 Grill - Remove/Replace Chrome Overlay?-image-1773188135.jpg
2013 V6 Grill - Remove/Replace Chrome Overlay?-image-2426594886.jpg
Old Aug 3, 2012 | 06:29 PM
BigR's Avatar
I noticed all of you have those dark colors...the chrome unfortunately really does stand out on these colors...I almost cancelled my delivery, but because my car is white...the chrome grill blended better than the blacks, grays and blue cars I noticed. A shame what they did to the CDN GTs
Old Aug 3, 2012 | 10:26 PM
watchdevil's Avatar
It's really silly to cancel delivery on a Canadian GT when you can change the grille to whatever you want. It's very fortunate that there are a wide variety of grilles that are interchangeable between all the 2013 non-Shelby models.
Old Aug 4, 2012 | 08:01 AM
cinque35's Avatar
yeah it def stands out a lot more on the darker colors, actually doesn't look bad on white
